Longboard 660kv motor HELP!!
INVAD3R   10 µW
10 µW
Post by INVAD3R » Jan 12 2015 8:36pm
Hello everybody I am literally a noob here, but have so far understood the concept of how to make an electric long board. I have already researched the parts I will be using and so far these are the parts I am planning to use:
*Turnigy Aerodrive SK3 - 5045-660kv
*HobbyKing Red Brick 60A ESC
*Turnigy 5000mah 5S 20C Lipo Pack
*Onda board wheels
I am considering in making this long board non-wireless and controlling it with a potentiometer because I want a cheap build since I don't have a lot of money and I am in a bit of a budget. I was thinking of wasting from $250 - $300/$350. This budget includes the board,wheels trucks etc. My question what motor would you guys recommend? and also what speed will this 660kv motor give me? I don't really need torque since I live in Arizona and where I live there isn't any hills so no need for torque, I think.I already know how to build the board, my only problem I don't have knowledge in these parts and concepts so this is why I need your guys help. Also if you guys have any suggestions you are more than welcome. :D
beto_pty   1 kW
Re: Longboard 660kv motor HELP!!
Post by beto_pty » Jan 12 2015 8:38pm
How much do you weigh?
On 5s youll be pulling more than 60 amps..
Youll need a hefty gear reduction to tame a 660kv.. like 5:1 maybe 6:1 on regular wheels
Maybe 12:1 on 7 inch ondas...
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
torqueboards   100 MW
Post by torqueboards » Jan 12 2015 9:22pm
To get 12:1 is nearly impossible. With 12T being the smallest you'll need 144T drive wheel.
I would opt for a 200kv to 280kv. I personally don't prefer to go much higher in KV rating. 300-350kv maybe.. If you do go for 600kv you'll have to kick if a ton on start-up if you want your motors not to overheat.
I would upgrade to a 120/150A Car ESC.
You can also get a $20 GT2B and/or Quantum Pistol Grip which isn't that much.
Btw good luck on $350. You might as well buy a Yuneec E-Go for $499.
DIYElectricSkateboard.com Electric Skateboard Kits
INVAD3R   10 µW
10 µW
Post by INVAD3R » Jan 12 2015 11:38pm
Thank you for your responses. I am considering going lower like you recommended I might go 280kv or 300kv max and see what occurs. What would you recommend to keep my budget maybe at max at around $250 or $350, and what parts may be useful since my whole budget will be used to the board and wheels and such materials and parts. Thank You
brent   1 W
1 W
Post by brent » Jan 12 2015 11:58pm
I think $250 is doable. 5065 270kV motors are common and good for flat ground.
I have a bunch laying around and could probably send them to you for cheap.
+ motor mounts, printed & polycarbonate pulleys, 6S 120A car escs, etc
/shameless plug
INVAD3R   10 µW
10 µW
Post by INVAD3R » Jan 13 2015 12:02am
I think that is perfect, and I am currently still looking for a job but once I get the money just let me know the price and I will consider it. Also I am going for maybe Mountain Board wheels or those that work in dirt and rocks since some sidewalks here are dirt and rocks and not concrete.
torqueboards   100 MW
Post by torqueboards » Jan 13 2015 12:22am
Nice setup brent. Looks good. Also what are you using for belt adjustment?
I sell $225 w/ free USA shipping for trucks, wheels, drive train, motor mount, bearings, spacers @ www.DIYElectricSkateboard.com
brent   1 W
1 W
Post by brent » Jan 13 2015 1:01am
I did multiple hole patterns for tensioning, but I haven't found a need for tensioning yet; the "middle" pattern is just the calculated center-to-center for a 17:40 reduction + 3 thou; the other two are spaced at something like ctc + 8 thou and ctc - 15 thou. Turning down the trucks and clamping makes for a super accurate center-to-center distance, and the ability to adjust angle.
A little restrictive when it comes to ratios, but the mounts should work with a couple different ratios (<3 thousandths off from calculated ctc)... 17:40, 15:38, 17:42, 10:36 #25 chain, etc... I have a list somewhere but don't have it off the top of my head.
I can probably do the following for $210 + shipping:
-turned down drive truck
-motor mount
-270kV or 230kV motor
-120A pre-programmed + pre-soldered 6S ESC
-17t pulley
-belt if you're using a 17:40 reduction
-hex drive screws + nuts for mount & motor
-whatever 3d printed parts you need (ie ABEC 11 wheel pulley)
-whatever electrical connectors you need
Throw in an extra $100ish and I can give you an extra motor + mount + ESC + belt + pulley set.
Downside is you're more restricted when it comes to gearing ratios, compared to Torque's kit. May be an issue if you're set on using pneumatic wheels.
( $250 is harder than I thought, hmm... probably a bit over $300 for a single drive? )
BShady   1 kW
Post by BShady » Jan 13 2015 1:13am
Cheapest I would go:
Hobbyking 150amp 6s car ESC- $60
Ntm 50/60 270kv motor- $45
MBS mountainboard with (air) wheels- $120 used
6s 5000mah lipo- $44 (I would get 2 6s 2560mah for smaller factor)
Gears and belts and screws etc.- $30
Gtb2 remote- $22
IMAX b6 Charger- $27 if you don't have one.
Total: $348
Make your own enclosure and power supply(from old computer).
If you could make your own mount then you will save some cash. Otherwise look to torque or Brent.
I also don't know what gearing you'll need.
Useing inflatable tires. While knock your range down to 5miles with only 5000mah battery add another $45 for 10miles.
torqueboards   100 MW
Post by torqueboards » Jan 13 2015 1:21am
Those are nice mounts anyhow brent :)
I have some bolt on's also that should be completed soon also. For bolt on those are a great deal.
1:2 for dual motor works well on 6s with a bit of a kick - you can up to 8s and go higher than 1:2 - 1:3.
17/40 should be good which is 1:2.35. For single, I would go 1:3 or 14/40 for 1:2.85 on 6s would be a bit slow but 8s would be nice.
INVAD3R   10 µW
10 µW
Post by INVAD3R » Jan 13 2015 8:25pm
Thanks for the offers and i will consider them once i get my job which hopefully will occur soon. I am thinking that torque isnt really necessary in my case since i am not going uphill or anything and speed is my main priority and that i can travel a good amount of time. Hopefully i can achieve this within the budget. I wouldnt mind controlling the motor with a potentiometer since its the easiest and best way to build this longboard within my budget.
