Scrub Psycho II mountainboard build
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 12:00pm
Hi!
This is my secont build(first was an longboard). Planned to 2 motor, but only 1 implemented. Maybe i will update if necessary.
Components:
Board: Scrub Psycho II (8” wheel, 6,1kg weight, max 80kg load!!)
Motor: Turnigy SK3 6374 192kv
ESC: HK 150A Car
Battery: Turnigy 6s 3000mAh 20c
Control: HK GT2
Transmission: 6mm ISO04 chain, 10T/45T sprockets (from Conrad webshop)
Calculated max speed 35km/h. Not measured the real speed, but enought for me :)
Always push start, very light throttle manage, onroad usage, no cogs.
Lipo enclouser in progress :)
Middrive hardtail e-bike build: https://endless-sphere.com/forums/viewt ... 28&t=91875
Scrub Psycho e-mtb build: viewtopic.php?f=35&t=66244
MBS Pro 12 e-mtb build: viewtopic.php?f=35&t=68710
Electric Drift Trike build: https://endless-sphere.com/forums/viewt ... 35&t=84936
vlaca2   10 W
Re: Scrub Psycho II mountainboard build
Post by vlaca2 » Jan 19 2015 12:03pm
Sprocket mount:
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 12:06pm
Motor mount:
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 12:09pm
Complete assembly:
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 12:12pm
Complete assembly:
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 12:14pm
Complete assembly:
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 12:16pm
In action :
benj   100 W
Post by benj » Jan 19 2015 12:22pm
Awesome, well done! No welding? That appeals to me :)
Is it just clamped with the u-bolts? Is there anything to stop the whole thing twisting round?
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 12:46pm
Thanks!
Yes no welding, only u bolts hold the mount. Im testing it a week, its ok. If fail i will report :)
torqueboards   100 MW
Post by torqueboards » Jan 19 2015 12:52pm
Looks great! Awesome. I have no doubt that will hold indefinitely. The Ubolts and Ubracket will help with strengthening it.
DIYElectricSkateboard.com Electric Skateboard Kits
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 1:03pm
Thanks!
I saw a broken welded scrub truck( maybe in french forum) so i chose this solution.
One motor, street usage, no jumps, its ok :)
torqueboards   100 MW
Post by torqueboards » Jan 19 2015 1:08pm
vlaca2 wrote:Thanks!
Looks like you could even fit two motors on their with the ESCs right behind it. :mrgreen:
vlaca2   10 W
Post by vlaca2 » Jan 19 2015 1:20pm
Yes, yes, this is the original plan :)
2x2.7kW.....
vlaca2   10 W
Post by vlaca2 » Jan 31 2015 6:11am
Update 1.
Added battery box and receiver box.
vlaca2   10 W
Post by vlaca2 » Jan 31 2015 6:14am
vlaca2   10 W
Post by vlaca2 » Feb 02 2015 3:59am
I resize pictures, now visible all :)
benj   100 W
Post by benj » Feb 02 2015 6:51am
Thanks for updating the pictures. Very inspiring build, I've been wanting to convert a board like this and I might have to take the plunge!
All we need now is some video of you in action :)
vlaca2   10 W
Post by vlaca2 » Feb 02 2015 8:00am
benj wrote:Thanks for updating the pictures. Very inspiring build, I've been wanting to convert a board like this and I might have to take the plunge!
Thank you Benj!
Video comming, maybe in spring :) (here 10cm snow, not ideal for e-mountainboarding :))))
matty_x   100 mW
Post by matty_x » Feb 02 2015 7:01pm
I have a similar mountain board that I picked up on the cheap.
Love the motor mount. I'm going to try to do that with mine.
Thanks for posting. Great ideas!
vlaca2   10 W
Post by vlaca2 » Feb 15 2015 11:43am
Thanks!
vlaca2   10 W
Post by vlaca2 » Feb 15 2015 11:45am
Toy camera onboard:
IMG_1127 copy.jpg (88.54 KiB) Viewed 5078 times
vlaca2   10 W
Post by vlaca2 » Feb 15 2015 11:53am
Speed test:
Results: 32,8 kph (calculated was 35)
Onroad, flat ground.
IMG_1136 copy.jpg (89.01 KiB) Viewed 5078 times
IMG_1137 copy.jpg (72.61 KiB) Viewed 5078 times
BShady   1 kW
Post by BShady » Feb 15 2015 9:21pm
What's the weight on your board? Those brackets and mounts look hefty!!
vlaca2   10 W
Post by vlaca2 » Feb 16 2015 2:49am
Hefty? Maybe, not measured. But the motor 850g (x2 when i install second), i think no problem 2stk 6mm alu and L bracket :)
Barnsieboy   1 µW
Post by Barnsieboy » Feb 26 2015 5:32am
Hey mate
First off, awesome board! Just out of curiosity how far or long do you ride on a charge ? Are you still running on the one battery ?
