Carbon fibre electric longboard
jacobbloy   100 W
Post by jacobbloy » Jan 29 2015 10:21am
I'm also hoping to do a test order for some carbon fibre foam core longboard decks.
I know the company who makes evolve carbon decks but there heat mould fee is $1500 and the decks are $300 each for samples under 100!
That have offered to do some normal airbag decks for me so there is no mould fee for testing! I have to order 10 decks and they are $200 each usd.
The design I want to do is similar to the rayne rival deck but with electronics holes in the deck.
can any one suggest any other methods of doing this, I want nothing hanging under the deck!
Iv looked at nomex or alloy honeycomb.
Nomex isn't that hard to make using a wood and nomex combo and you can get some good 3M glue to do the shape moulding quick and then cover the rest in carbon fibre but price is up there!
My other option is for $360 usd I can have a completely 6065 alloy deck made with a lid on top and bottom! Also very heavy.
But I can remove all heat sinks from bms and ESC and basically have a giant cooling box for all my electronics! But if there's a big short and I don't insulate good enough I could get a good shock!
The foam core will be 16mm thick with 1.5mm carbon on top and bottom!
I have been talking to a local surfboard designer and he help me with a design to keep the deck strong.
The deck will have sections for components like battery ESC each section will be separated by cross sections of foam and fiber to keep the deck strong in the centre! There are 6 sections 70mm x 170mm big enough to fit a zippy 2s 8000mah battery pack 4 of them so 8s or 10s if you have no BMS also to fit an alien twin 120a ESC! And a Bms the alien ESC with need 4mn shaved off of the heatsink shaved off
The only other option I have to save cost is I can have them cut out the section in a wood longboard deck and the cover it in carbon fibre.
This Way only costs $150 usd but will be stronger but heavier but will already have a nice shape.
I want opinions and advise expireance is most welcome offers from ppl who can do at home would be good!
My sales thread for the test carbon foam or carbon food decks URL is http://endless-sphere.com/forums/viewto ... 31&t=66503
torqueboards   100 MW
Re: Carbon fibre electric longboard
Post by torqueboards » Jan 29 2015 10:53am
Would be nice to have it all in one enclosure. I think that's more "a want" than a need. Simply, we just need a more durable, universal enclosure.
If you can make it happen would be nice. An on-board battery pack would be ideal. I might be in for one depending.
DIYElectricSkateboard.com Electric Skateboard Kits
bandaro   10 kW
Post by bandaro » Jan 29 2015 7:15pm
Very nice, I'm working on a design for a carbon deck myself for a current electric project with a low density core and battery housing. I currently make and sell custom longboard decks so making one for myself was a no brainer (I haven't actually bought myself a skate deck yet, just keep the proto's for myself). Would like to make them to sell to the community or as complete builds in the future.
Edit: Not a fan of the shape, the neck is too short and runs the risk of mad wheelbite, especially with the large flywheels. Being a dropthrough also adds to the problem. Also, surfers love the centre stringers, but careful how thin the edges are - having build boards with handles, the thin edges on your design are liable to break, compromising the whole deck so look into this when engineering the layup.
jacobbloy   100 W
Post by jacobbloy » Jan 29 2015 7:21pm
bandaro wrote:Very nice, I'm working on a design for a carbon deck myself for a current electric project with a low density core and battery housing. I currently make and sell custom longboard decks so making one for myself was a no brainer (I haven't actually bought myself a skate deck yet, just keep the proto's for myself). Would like to make them to sell to the community or as complete builds in the future.
Would love it if you could share some expertise but you don't have to share secrets. Photos of prototypes?
okp   100 kW
Post by okp » Jan 30 2015 1:28am
great post - what about working on a Mach 1 shape ...!
bandaro   10 kW
Post by bandaro » Jan 30 2015 1:38am
Don't have a proto with battery compartments yet, but I have made a 'proof of principle' board with a low density core and carbon bottom to test the theory I will make the electric proto on. This one turned out really well, stronger than I expected (has zero flex) so should be good to make the actual proto. I keep changing the design but not significantly, should be good to start building on the weekend, hopefully get the pressing started on monday. I'm expecting this build to take about 10 hours in the shop so hopefully have it done soon. Doing multiple pressings for a proto always takes forever to finish...
Early press and trimming:
First press
Finished, you can see how it steps up in thickness about 50mm into the board. Final thickness is about 16mm.
finished build
A mini I built recently:
mini
The mach is a sweet deck, but would need to tweak the shape a little, they are prone to getting wheelbite on larger wheels. Feel free to shoot me a pm to get my thoughts on a design/layup if you are building something.
okp   100 kW
Post by okp » Jan 30 2015 2:25pm
this one in top mount could do the deal
bandaro   10 kW
Post by bandaro » Feb 05 2015 11:17pm
Wee little update on my proto, got a box of goodies today, including the nyloc nuts. I have been pressing it up over the week in a few presses to test where the weak spots will be as I go, so I'm ready to drill some holes, inset the nuts into the deck so you only see the screw heads on the outside and lay the inside layer of uni carbon over the deck this weekend. On monday I will cut out some graphics and press the outside layer, so it looks like that first board I posted above. Battery compartments were made to fit the cells I have - 2x 6s 5000mah lipo reconfigured to fit.
After that it will be cutting the motor mount out on monday hopefully and waiting for the last bolts and switches to get here, then final assembly and I should be running. Then I can put some hours into the redesign of a controller!
PracticalProjects   10 W
Post by PracticalProjects » Feb 07 2015 3:23pm
That prototype version you made is absolutely beautiful! Love how you have combined the wood with the composites. I am looking forward to seeing your progress...
Luther Blissett   10 mW
Post by Luther Blissett » Mar 08 2015 5:15pm
Just stunning. :shock:
bandaro   10 kW
Post by bandaro » Mar 09 2015 3:53am
Sorry for the lack of updates guys, but truth is I have been way delayed, waited over a month for some gear to embed into the layup (since started a paypal claim and re-ordered from someone else) and have a bunch of boards in the works for clients and an arts festival this weekend, as well as work. That being said, I will have a rolling prototype to test by the weekend, and it will be powered next week all going well. Will have a similar finish to the proto - same carbon weave with a piece of timber in the centre. Obviously, a very different shape, both the board styling, concave and timber graphics.
torqueboards   100 MW
Post by torqueboards » Mar 09 2015 3:57am
Can't wait to see it. :)
Jebe   1 mW
Post by Jebe » May 22 2016 1:18pm
Bump!
