Penny board 3d printed build
strygw   1 µW
Post by strygw » Mar 16 2015 8:35pm
Just wanted to share my penny board build.
Its all 3D printed in PLA, except for the casing and motor pulley (since it needs to take more load). So far it has survived slightly above 120km, and is able to reach 20km/h-ish. The motor does get warm, and there is a piece of cardboard separating the face from the plastic. The mounts are crudely bound by cable ties, but I will be using countersunk screws once they arrive.
While I do have a workshop that I can use, I wanted to make one that would require minimal modifications to the board (ie no welding). Also, the 3D printing process allowed me to iterate very quickly.
The main pulley is bolted to the wheel to allow the torque to be transmitted without slipping. I originally wanted it to be a simple interference fit, but the motor was too powerful, and kept heating up and melting the plastic.
Also, anyone able to guide me on implementing regenerative braking?
chuttney1   100 W
Re: Penny board 3d printed build
Post by chuttney1 » Mar 16 2015 10:02pm
Nice job on the 3d printing. Regenerative braking can be only done on a speed controller that has the feature, like Vedder's ESC, but is not plug and play yet. Some RC ESC may have it depending on the brand, but the efficiency may be very low.
torqueboards   100 MW
Post by torqueboards » Mar 16 2015 10:33pm
I believe all BLDC motors have regenerative braking. Depending on the ESC some are able to regenerate more or less. Ideally, it's around 7-9% regenerative braking which isn't much.
DIYElectricSkateboard.com Electric Skateboard Kits
sami   1 W
1 W
Post by sami » Mar 16 2015 10:55pm
That is a great job! Any chance of sharing the 3d files?
How does it handle the torque from the motor?
okp   100 kW
Post by okp » Mar 17 2015 1:39am
nice ! looks sweet - which software did you use for the 3D modeling?
ps: you can remove the steering wheel on the radio :)
sami   1 W
1 W
Post by sami » Mar 17 2015 4:45am
forgot to say, as mentioned you need an ESC that allows braking, such as a car ESC.
strygw   1 µW
Post by strygw » Mar 17 2015 7:59pm
Yeah, right now im using a cheap ESC that doesn't have a very pleasant acceleration curve. Will probably look into Vedder's ESC when there is a preorder available.
I modelled it in solidworks, have attached the files - haha please don't judge the steps that I took, it's quite a crude job. And share any modifications that you make!
https://www.dropbox.com/sh/bpffjbznr2q5 ... Mckba?dl=0
sami   1 W
1 W
Post by sami » Mar 17 2015 8:06pm
thanks for sharing mate much appreciated. i dont judge as i dont have your skills ;)
the 150A car ESC from Hobbyking is apparently a good one, they werent in stock in Aus so i ordered a different (wrong one :() these allow you to program timings and so on. you have made a great start though mate!
levanter   1 µW
Post by levanter » Jan 15 2016 10:01pm
Hi, could you post the file for the other side of the motor mount?
Thanks!
saul   1 W
1 W
Post by saul » Jan 15 2016 10:52pm
I've been wanting to try a printed motor mount but I didn't think pla could handle it, can you post some more picture of the mount? maybe the stl files?
Builds:
97mm Fly wheels + tiny 85kv + 12s Vesc
https://endless-sphere.com/forums/viewt ... 35&t=76450
more to come...
flimflamphlegm   10 µW
10 µW
Post by flimflamphlegm » Jan 16 2016 2:17am
I'd also be interested in the .stl files, as well as the parts you used (trucks, wheels, belt, motor...)
Electricskatefinatic   1 µW
Post by Electricskatefinatic » Jul 02 2018 5:58pm
Hey I’m the Dropbox download there is only half the mount how do I get the other half that you screw it to
