New E-skateboard motor drive parts
Postby DingoMan » Sun Apr 19, 2015 2:02 pm
:shock: New to the community, decided to make my own motor drive parts. Using laser and waterjet just need to finish off with the CNC machine. Here's a few pics! I'll T6 aircraft aluminum, just need to do the CNC probably do tomorrow.
Last edited by DingoMan on Sun Apr 19, 2015 3:03 pm, edited 3 times in total. View post history.
DingoMan
Re: New motor drive parts
Postby riba2233 » Sun Apr 19, 2015 2:16 pm
You can upload pictures to imgur.com, no size limitation. Once uploaded, select large thumbnail, copy BB code and paste it here.
My electric moped: http://www.evalbum.com/4966
Spot welders for sale!
viewtopic.php?f=31&t=68865
riba2233
Postby DingoMan » Sun Apr 19, 2015 2:57 pm
Just posted the pics!
DingoMan
Re: New E-skateboard motor drive parts
Postby torqueboards » Sun Apr 19, 2015 3:26 pm
Looks good. Similar to lpbug.
DIYElectricSkateboard.com Electric Skateboard Kits
torqueboards
1.21 GW
1.21 GW
Postby DingoMan » Sun Apr 19, 2015 3:59 pm
Yes the retainer clip does look like his, but mine is for a real Abec11 not a clone. The motor mounts in the wheel hub are completely different and different width. My motor mount hasn't been drilled yet or tapped, It is a split
two bolt system rather than one - i'm just holding the back of the clamp with my finger. I just built these cause my boys wanted some boards and I thought they were too expensive on the market. Having fun doing this I -already have an idea that's quite innovative. I probably pushed to this too early still have to CNC. Thinking about doing my own motors and electronics?
Last edited by DingoMan on Sun Apr 19, 2015 4:14 pm, edited 1 time in total. View post history.
DingoMan
Postby torqueboards » Sun Apr 19, 2015 4:52 pm
DingoMan wrote:Yes the retainer clip does look like his, but mine is for a real Abec11 not a clone. The motor mounts in the wheel hub are completely different and different width. My motor mount hasn't been drilled yet or tapped, It is a split
Nice.. Impressive if you do your own motors + electronics.
torqueboards
1.21 GW
1.21 GW
Postby DingoMan » Sun Apr 19, 2015 5:10 pm
@ torqueboards- thank you for the kind words. It's really a matter of if I have enough time, I do have experience in manufacturing but I'm doing this for my kids and myself not really planning on going into the skateboard business. Although I must say this brings me back to my youth that sometimes seems so far gone. LOL
DingoMan
Postby matty_x » Sun Apr 19, 2015 11:24 pm
Those look great. Nice job!
matty_x
Postby onloop » Mon Apr 20, 2015 12:45 am
what width belt will you use? looks like 15mm.. so can't have dual rear drive? :cry: ... unless you use really small motors i suppose they will fit.
onloop
Postby torqueboards » Mon Apr 20, 2015 12:47 am
onloop wrote:what width belt will you use? looks like 15mm.. so can't have dual rear drive? :cry: ... unless you use really small motors i suppose they will fit.
I wanted to switch to 6364 motors too and 15mm belts but no room on the truck :(
torqueboards
1.21 GW
1.21 GW
Postby DingoMan » Mon Apr 20, 2015 8:12 am
We will not be able to do dual rear motors. Belt with is 15mm, and motor size is 6374 – (go big or go home motto). For dual motors we will do opposition front and rear trucks. I like the concept of hub Motors in wheels but would like to see how they fare with time specially with the small diameter bearings people are using for the outside axel of the motor? There actually is a stronger, lighter more torque Electric motor than a brushless Technology already done not in the RC realm. I just don't know if they can make it small enough to fit in a skateboard wheel or if the company that owns the patent and development rights to this would have any interest in producing for this application.
DingoMan
Postby DingoMan » Mon Apr 20, 2015 8:21 am
In the beginning I was thinking of making my own trucks hangers with the motor mount CNC as one part, we can obviously do any width desired. But right now I only have so much time and I just wanted to whip these things out for the boys. I looked at other designs out there and we actually did the designs pretty much in one day.
DingoMan
Postby DingoMan » Mon Apr 27, 2015 8:51 pm
After some mill work, one piece design for strength and Rigidness.
DingoMan
Postby DingoMan » Mon Apr 27, 2015 8:53 pm
With motor and belt.
DingoMan
Postby DingoMan » Wed Jun 17, 2015 7:43 pm
A few new boards
DingoMan
Postby torqueboards » Wed Jun 17, 2015 8:23 pm
Nice setups :)
torqueboards
1.21 GW
1.21 GW
Postby handbaked » Sun Jul 19, 2015 8:05 pm
Do you sell these parts? Just this eve started looking into a e-board build.
handbaked
Postby sl33py » Wed Jul 22, 2015 2:03 pm
handbaked wrote:Do you sell these parts? Just this eve started looking into a e-board build.
You have a local supplier i'd check with as well. Alien Drive Systems. Richard/Beetbocks was really helpful when i first looked to build my board. Tons of info shared and responsive. Helps (or might) that he's in the UK and local to you.
Also check out the soon-to-be-released by Torque/DIYElectricskateboard.com motor mounts on his site. Adjustable angle and seems like it's also modular for multiple truck options.
Welcome and GL!
Last edited by sl33py on Wed Jul 22, 2015 2:07 pm, edited 1 time in total. View post history.
sl33py
Postby DingoMan » Fri Mar 10, 2017 12:00 am
Selling the two boards and all the new parts I manufactured-
Enough hardware to make 10 more motor and wheel Drives, -1 extra dual motor and single motor electronic speed controllers >12s- Motor pulley's, connectors and parts. Truck bracket motor mounts will have to be drilled and tapped for two bolts and plained down a little. Will give connection to buyer to my design plans and water jet and laser cutting companies if They want to produce more. Wheel hub and pulley sprockets finished products also motor pulleys. I'll explain pretty much everything -take a look at the finished boards four example and guide. Extremely fast! Boards Are barley used, used MapMyTracks GPS speed avg 40s - not sure if it was accurate but highghest speed recorded was 54 mph?
DingoMan
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 4 guests
