DIY Stealthy Longboard Build Log (Integrated batteries)
Marcin   1 W
1 W
Post by Marcin » May 12 2015 6:53pm
Hi! As a new member I feel like I should introduce myself first;
My name is Marcin, 21 and I live in London, UK. I have a huge passion for all kinds of DIY projects ranging from CNC routers and 3D printers to various electronic bits and bobs. Quite recently I have set my mind to make myself an electric way of transportation, and after some quick research I have decided to do it in style! I always loved skateboarding, and having seen some kickstarter longboard projects I have decided to build my own.
Build goals:
- Stealthy, non intrusive look. I want to hide as much as possible within the deck itself, more on that later
- ~30KM range. This is a huge requirement for me, If I manage to travel +- 20km daily on the longboard it will save me £10.20 on daily public transport. Added bonus here is that I only weigh 58Kg :)
- Small, reliable remote controller powered by an Arduino Nano with a 2.4ghz module and perhaps built-in screen for voltage / distance monitoring
- To have a lot of fun!
BoM (Part list)
- 42"x9.5" Deck http://www.ebay.co.uk/itm/361211929333?var=630567784894
- 18 5000MaH LiPo cells that will be integrated within the deck itself http://www.hobbyking.com/hobbyking/stor ... ouse_.html
- Turnigy Aerodrive SK3 - 275kv http://www.hobbyking.com/hobbyking/stor ... ouse_.html
- Turnigy Aquastar 120A ESC http://www.hobbyking.com/hobbyking/stor ... ouse_.html
The idea behind this longboard is to make it look as sleek as possible, therefore I have chosen to create 18 pockets in the deck to fit the individual LiPo cells, covering them with a large 1mm thick aluminum sheet that will be anodized black upon project completion. I am planning to anodize the trucks, motor mount and the bottom sheeting cover in black, for a stealthy look
While I am still waiting for most of the parts to arrive, I have started soldering the ESC and the motor making sure that the joints won't break as it seems to be quite common with DIY boards ending up with fried motors/speed controllers
Here's a picture of my CNC router that I will use to make quite a few custom aluminum parts for this project:
Stay tuned for more ^.^
Marcin   1 W
1 W
Re: DIY Stealthy longboard build log ^.^
Post by Marcin » May 12 2015 6:58pm
=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= RESERVED =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
sami   1 W
1 W
Post by sami » May 12 2015 7:32pm
onboard for this. waiting for my CNC to arrive (stuck in customs) good luck and keep the updates coming mate :)
just noticed you chose a watercooled boat ESC.. you may want to change that to a car ESC for braking and running without the need for water cooling.
Marcin   1 W
1 W
Post by Marcin » May 12 2015 7:44pm
Thanks Sami, good luck with the CNC!
I am going to modify this ESC quite a bit to make it bolt-on to my deck making the aluminium sheet act as a giant heat-sink. Apart from that, this ESC does have a brake, we'll see how that goes
Cheers
beto_pty   1 kW
Post by beto_pty » May 12 2015 7:54pm
regarding the brake... check the manual... the 80 amp version of this esc included brake but it was a typo... hope yours isnt
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
sami   1 W
1 W
Post by sami » May 12 2015 7:55pm
sounds good Sleziak, looking forward to seeing it come together.
Marcin   1 W
1 W
Post by Marcin » May 12 2015 8:01pm
@Beto, it does have a brake, I've tested it. It does seem a bit harsh, not sure how it will translate into stopping a 60kg object but the worst case scenario would be writing a custom firmware for it and integrate the remote receiver to the ESC, omitting the arduino.
Upon taking the ESC apart, it contains an Atmel microchip which is very common in terms of speed controllers, I'd need to port an existing opensource project, and make sure that I don't let the magic smoke out haha
Regards
Marcin   1 W
1 W
Post by Marcin » May 13 2015 3:48pm
The board has arrived today! After a short cruise I have disassembled it and started carving out the battery slot, quite pleased about the result.
I will now start adding support struts in between the batteries before I make the bottom aluminium panel
torqueboards   100 MW
Re: DIY Stealthy longboard build log (Integrated batteries)
Post by torqueboards » May 13 2015 4:02pm
Sweet setup!
DIYElectricSkateboard.com Electric Skateboard Kits
777arc   10 W
Re: DIY StealthyLongboard Build Log (Integrated batteries)
Post by 777arc » May 13 2015 4:53pm
My turnigy trackstar gen II has brakes, but they are unusable because sometimes they brake too suddenly and it can get dangerous. VESC brakes work great :D
Freshair   100 W
Post by Freshair » May 13 2015 5:42pm
sleziak wrote:The board has arrived today! After a short cruise I have disassembled it and started carving out the battery slot, quite pleased about the result.
Nice work Sleziak! Definitely following your build!
Low impact to no impact
sl33py   10 kW
Re: DIY Stealthy Longboard Build Log (Integrated batteries)
Post by sl33py » May 13 2015 6:17pm
Looks like a cool project! Definitely will follow. Best of luck!
Ohbse   10 kW
Post by Ohbse » May 13 2015 6:25pm
Very cool, great idea with routing out for each cell. Keep it up!
Marcin   1 W
1 W
Post by Marcin » May 13 2015 7:28pm
Thanks for following guys!
I went ahead and started wiring the batteries. LiPo cells are known to be hard to solder because they have aluminium terminals, setting my soldering iron to 450 degrees C, applying liquid flux and soldering the point as fast as possible seems to have resulted in the strongest joints. I've also folded the terminals in two, locking the wire in the fold before soldering
Mess
A little bit of cable management later ...
Regards
Freshair   100 W
Post by Freshair » May 13 2015 8:45pm
Looking good.
So aside from having an aluminum sheet covering the bottom, how else are you planning on securing these cells?
Marcin   1 W
1 W
Post by Marcin » May 13 2015 8:54pm
@Freshair;
There will be double sided mounting foam on both sides, similar to this but thinner: http://hobbyking.com/hobbyking/store/__ ... thick.html
Each row of batteries will also be separated by either a 3D printed plastic or CNC cut wooden support, so if they ever slide for whatever reason, no damage will be caused
Regards
CSN   100 W
Post by CSN » May 13 2015 8:59pm
How many wood ply's are left under the battery pockets?
Marcin   1 W
1 W
Post by Marcin » May 13 2015 9:03pm
@CSN 3 out of 9
Regards
Freshair   100 W
Post by Freshair » May 13 2015 9:03pm
You are tempting me to do a variation of this with my upcoming project!
How will you charge your batteries, are you incorporating a bms into your system?
Marcin   1 W
1 W
Post by Marcin » May 13 2015 9:11pm
@Freshair
A BMS would be a dream, but I am lacking space for anything more. I'll have a discrete connector on the underside of the board bringing out 3 cells per pin (6 in total) , which I will charge using a LiPo balancer. I am slightly concerned about having 3 cells in series x 6, might cause balance issues but time will tell. Regards
sami   1 W
1 W
Post by sami » May 13 2015 11:00pm
nice work man and good progress so quickly! keep up the good work
Marcin   1 W
1 W
Post by Marcin » May 14 2015 4:54pm
Today my 1mm thick sheet of aluminium arrived, so I've started working on the bottom panel.
After a quick assembly I have realized that due to the curved shape of the sheet, the deck is more sturdy than it was originally, so I have decided to skip the supports in the battery slot.
Drawing a rough guideline to be cut using my grinder
10 minutes later ...
Adding protective padding to the battery terminals to keep the wires from moving and cover the exposed terminals
20 minutes of filing later ..
I am now ready to shape the edges of the sheet to match the shape of the deck, however I am not really liking the result so far. I might've rushed this process a bit...
If anyone knows an (easy) way to straighten the edges of this without adding more screws, please let me know
Regards, Marcin
sl33py   10 kW
Post by sl33py » May 14 2015 5:35pm
what about re-cutting the sheet to only cover the batteries? having it captured under the trucks will add rigidity (possibly your intent), but will add weight and make accessing the batteries a lot more difficult!
Just cutting to cover the section of the deck you have batteries in, would help re-do your edges, and make access later easier!
Not sure how difficult it is to re-cut, or if you are trying to minimize flex w/ this as reinfocement. I'd be worried a bit about weight and would try to minimize w/ less aluminum. Possibly add a layer of CF to stiffen w/o as much weight?
GL and awesome project!!
sl33py   10 kW
Post by sl33py » May 14 2015 5:39pm
not sure how well that aluminum will "mold", but what about adding your cut out section of wood back to the deck (so you don't press/damage lipos) and adding pressure to form it better to the deck? Worried this would take tons of weight and more likely to damage the deck w/ it being reduced strength with the cutout.
I think you might need to hammer it on a form and slowly add the angle to form to the deck flush. An art (if you've ever seen a body shop guy do with steel for a replacement).
GL!
bandaro   10 kW
Post by bandaro » May 15 2015 4:15am
sleziak wrote: I am now ready to shape the edges of the sheet to match the shape of the deck, however I am not really liking the result so far. I might've rushed this process a bit...
Thats not good...
But I assume you are meaning for the curve in the deck, because screwing a flat sheet of alu onto it will result in a "springy" feel every time you move your foot. That's not good.
So, the only ways I see are to either get 2 glue lines on it by pressing it onto the deck curvature in a vac bag with a layer of fibreglass or something on each side, or to roll it through a sheet metal roller. Rolling is simpler, lighter and cheaper but only if you have a roller. You can do the vac bag method for less than 5 euro plus the glass and resin costs. Use a pvc vinyl from a hardware store, some regular, 50mm clear packing tape to make the "bag" and then an old fridge compressor for the vacuum. You could try clamping and bending the alu, but this will only ever get it close.
That being said, if it is a tub concave or anything other than a straight radial, a roller won't do it either. Not properly anyway. Any chance of getting a 1.5mm veneer and glassing both sides of it in a bag onto the deck? this would probably be the best option.
Let me know if you want more details on the options, I make longboards regularly for a living.
