Offroad Onda with integrated electronics
benj   100 W
Post by benj » May 26 2015 6:37am
Something a bit different I think :) Here is my take on an Onda
It's an Onda Core with Trampa MTB wheels, and to make it semi-stealth - electronics mounted in-deck.
It looks pretty awesome I think, very happy with it. The ride is nice and soft and smooth.
It's been designed as a 'grass surfer' - so pretty mellow 6S and not meant for real off road. It's way more fun than the MBS eMTB because of the flex and low ride height. Perfect board for the back of the car and chasing my daughter round the park on :D
okp   100 kW
Re: Offroad Onda with integrated electronics
Post by okp » May 26 2015 6:48am
awesomeness. please post a video of a ride ! what are the electronics used ? did you made your mount yourself ?
you should round the edges of the mount and paint it black or red to match the wheel rims!
what is the total cost of this ?
made_in_the_alps_legacy   10 kW
Post by made_in_the_alps_legacy » May 26 2015 6:50am
Oh Owww... and you haven't told us ? :twisted:
very nice work integrating the electronics :wink: may I ask a bit more about the spécifications (motor kV and ratio)
(I think it's a Core, not a Vibe)
benj   100 W
Post by benj » May 26 2015 7:04am
It's a home-made mount. Just simple 6mm aluminium plate, cut to make a clamp around the square truck hanger.
Electronics are Alien micro ESC, twin 3S 5000mah Lipo and 63mm 130KV Alien motor.
Gearing is 50 tooth sprocket and 20 tooth pulley, 2.5/1 ratio. ISO 08B1 chain.
Thanks @made_in_the_alps_legacy - you are right it's a Core (edited above!)
@okp - yeah for sure! I must get some black paint and round off those corners...I made the mistake of not doing it first - and now I just want to ride it :lol:
magiced   1 mW
Post by magiced » May 26 2015 7:08am
Very nice and compact! I particularly like (what i'm assuming is) the XT charging socket built into the deck at the rear. Neat!
Tartopom   10 mW
Post by Tartopom » May 26 2015 9:10am
like it a lot!
Maybe this will push me to convert my ONDA CORE ;)
torqueboards   100 MW
Post by torqueboards » May 26 2015 9:38am
Haha that's sick! Nice idea!
DIYElectricSkateboard.com Electric Skateboard Kits
Wayno   1 mW
Post by Wayno » May 26 2015 9:48am
Sweet! Is that an LED or button by the XT plug? Do you have a power switch or do you manage that with the connectors?
Slowrider   100 mW
Post by Slowrider » May 26 2015 3:27pm
Super nice,
Are you using existing cavities in the board for the battery or have you carved them out ourself ?
Tartopom   10 mW
Post by Tartopom » May 26 2015 4:23pm
The under of the deck is like a matrix.
Then you just have to cut the parts you don't need to put the batteries. Smart ! :-)
psychotiller   10 kW
Post by psychotiller » May 26 2015 8:14pm
Did you reinforce the deck somehow after you cut out the structural fins for the batteries? Not sure how much you weigh or how much offroading you plan to do, but you cut out a pretty good percentage of the boards structure right out from under your front foot.
All of that aside, this build is inspiring. It looks really nice!
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttp://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through http://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
benj   100 W
Post by benj » May 27 2015 4:17am
Thanks for the comments everyone, glad you like it :)
Wayno wrote:Sweet! Is that an LED or button by the XT plug? Do you have a power switch or do you manage that with the connectors?
It's a button for antispark and the XT plug is the power switch/key. I didn't have a nice power on switch like Torque/APS sell, but the setup fits nicely in the gap.
psychotiller wrote:Did you reinforce the deck somehow!
No, but I think I will. There is a lot of material removed and the board is certainly more flexy after being modified. If I jump on it the belly hits the floor.
It's not a board for heavy offroad use, but I still think some reinforcement could be a good idea.
benj   100 W
Post by benj » Jun 16 2015 3:32pm
Summer evenings, sunsets, and a cruise round my local woods. Perfect evening! Had to post this pic...
Post by made_in_the_alps_legacy » Jun 17 2015 1:07am
Nice, thxs for sharing -
forgot to ask earlier : did you get those MBS wheels with 8mm ID bearings included ?
benj   100 W
Post by benj » Jun 17 2015 3:09am
No, I got lucky with the bearings. The Onda 8mm bearings fitted right inside the MBS wheels, where the axle tubes normally go!
I kept the 10mm bearings on the inside and outside as well, so it's kind of a sandwich 10mm, 8mm, 8mm, 10mm. The 8mms are right inside the hub shaft.
Post by made_in_the_alps_legacy » Jun 17 2015 3:25am
woow, that's very good to know, that those MBS wheels have the same bearing OD that the original bearing
I think I would have put the "working bearing" (8mm ID) on the outside, so 8-10-10-8, but it's not really an issue
..or I misunderstand because on your pictures it seems there is room left even with a pile of 4 bearings per axle
benj   100 W
Post by benj » Jun 17 2015 5:44am
Those first pictures are misleading. They don't have the 10mm outside bearing, and without that - the wheels fell off ;) It's a very close fit with all 4 bearings on, but enough to get good purchase on the nut.
You can't put the 10mm inside the hub shaft because it's an 8mm shaft ;)
benj   100 W
Post by benj » Jun 17 2015 7:59am
Oh, and importantly - these are not MBS hubs.
They are Trampa Primo hubs. The 8mm bearings don't fit my MBS wheels!
beetbocks   10 kW
Post by beetbocks » Jun 17 2015 9:01am
really nice..well integrated..
why dont you just make some thick washers to replace the 10mm bearings..so you can get more thread on the nut..?
