Open Source Arduino transmitter/receiver for (V)ESC
vedder   100 W
Re: Open Source Arduino transmitter/receiver for (V)ESC
Post by vedder » Aug 17 2015 2:04pm
I got some PCBs from Jacob a week ago and yesterday I spent all day soldering, debugging and testing:
I had to make a patch for the regulator to work:
A CP2102 PCB makes a built in programmer:
USB Port for programming and charging:
Here ts is next to the nyko kama:
I went for a 6km ride yesterday and it worked perfectly. I have tested the nyko kama with my early version of the PCB for months now and it has been super reliable, so this one should also work well.
The features of this nunchuk are:
* The connection is solid and reliable.
* Built in rechargeable lipo battery and built in charger
* USB port for charging/uploading firmware/configuration/debugging
* Standby time: over 100 days on a full charge
* Usage time: almost 2 days on a full charge (about a month if the longboard is used 1 - 2 hours every day)
* Lighter and smaller than the nyko kama
* Charge time: 1 - 2 hours
Much of the time I spent yesterday was on testing the power consumption in low power mode and how the charger works, which was much better than I expected. First I thought a power switch would be needed, but that does not seem to be the case unless you intend to leave it without charging the battery for more than 100 days.
I will help Jacob with updating the design a bit with the following:
* Connect the regulator correctly
* Remove some resistors that aren't needed
* Change the joystick footprint and position to make it fit better
* Add a CP2102 USB-to-UART chip to the PCB so that the programmer is build in. This will allow a twice as large lipo battery which doubles the standby time and usage time.
* Add something to make the MCU able to measure the battery voltage.
Some of my projects: http://vedder.se
Support my open source ESC development with a small donation
erwincoumans   100 W
Post by erwincoumans » Aug 17 2015 3:08pm
Hi Vedder, I love the controller design and hardware and would like to try it out. Is there already a repo with hardware/PCB and BOM, or do you/Jacob plan on selling assembled parts soon?
Nordel wrote: :?: I thought I would first have to upload something from link in the Readme. :?:
This comment doesn't make sense to me. Can you please share an updated readme that makes sense to you?
Well, the nRF24L01+ is very reliable, especially when you use the PA, LNA version. I haven't read your link, but it uses the default Nunchuck bluetooth communication? Some people tell it is unreliable.
I found the nRF24L01+ reliable enough, this one: http://www.amazon.com/Arrela%C2%AE-NRF2 ... 4l01%2B+pa
This is the nRF24L01+ with PA and LNA antenna:
http://www.amazon.com/Studio-Bazaar-wir ... 4l01%2B+pa
Cheers,
Erwin
vedder   100 W
Post by vedder » Aug 18 2015 3:16pm
erwincoumans wrote:Hi Vedder, I love the controller design and hardware and would like to try it out. Is there already a repo with hardware/PCB and BOM, or do you/Jacob plan on selling assembled parts soon?
I will upload the design to github when I have tested it and I think Jacob will make sure that controllers can be bought as kits or maybe even assembled.
Here is what I did today after work:
Schematic:
http://home.vedder.se/public/pictures/N ... kRF_V3.pdf
I have added the cp2102, moved everything around to place the connectors so that it is easy to solder cables to them and moved the joystick a bit. The regulator connections are also fixed. A USB connector can be soldered directly to the pads for charging, programming and communicating.
One feature I might work on is to make a wireless connection from BLDC Tool to the VESC using the USB connector on the nunchuk :-)
onloop   10 kW
Post by onloop » Aug 18 2015 9:24pm
That's so cool!...
Its great to see some progression with this.
Its also great when people in two parts of the world can work together to create some awesome stuff.....
torqueboards   100 MW
Post by torqueboards » Aug 19 2015 12:09am
Amazing! Well done. :mrgreen:
DIYElectricSkateboard.com Electric Skateboard Kits
jacobbloy   100 W
Post by jacobbloy » Aug 19 2015 12:14am
I have a box on my kitchen table with 100 nunchuck shells ready for a kit, it will come with a 300mah lipo and the new PCB that Vedder helped me with, but this all needs to be confirmed, if ppl want just nunchuck shells from me then they can do that also, and yes the PCB will be put on GitHub.
killisch   100 mW
Post by killisch » Aug 19 2015 2:04am
I'll be in for at least 2.
Possibly 10 depending on final price.
Cheers
RollingGecko   100 W
Post by RollingGecko » Aug 19 2015 4:32pm
Hi,
I want to jump in the discussion. The controler you developed is realy smart and fits perfectly to your VESC BLDC which I use now for some time and I must say that it a perfect esc! But I want also keep the discussion upright that started on this thread from erwincoumans about the arduino based controller. The Idea is relay smart for me because I get a lot experience with the arduino and want to jump on this project. I know about the remaining ressources of the VESC, but I'm far away to understand the code with its underlying ChibiOS/RT. So it would be great to get a open, well documented interface towards the VESC over the UART to realize a control Arduino based for those (like me) who have ideas that can be easily realized on an arduino platform (or lets say easier for non professional coders). I want to catch up the project from erwincoumans and support him if he wants to.
From my side, I defined the following requirements:
  • - Biderectional communication over NRF24L01 secured by a checksum and predefined fixed MAC address
  • - Configurable: PWM or serial communication to ESC (for VESC or other ESC)
  • [- Predefined PINs for 2812 LED, free usable output (for a horn?) and additional inputs for e.g. stand sensors/list]
    • - Usability of all features of the VESC like PID control etc.
    • - feedback for board voltage etc. over LED. In a next step maybe also the usage of a OLED
    Especialy for the communication to the VESC I hope of the support of Vedder to offer a documented UART message interface.
    Nice would be:
    Message based and documented protocoll with cheecksum
    Upstream:
    • UART based application like the nunchuck with PID etc.
    • UART based current control with break
    Downstream:
    • Input voltage
    • ERPM
    • current
    • 'Cosumed current [mAH]
    • Wh in/out
Within the Arduino I think it would be nice to implement also Smoother from wiiceiver and other features. Post your ideas if you want.
Vedder, maybe we can come together in a skype session to discuss a possible UART protocoll for the communication? I can send you my contact over PN or Email if it is OK for you.
Regards
Andy
Github: https://github.com/RollingGecko
ArduBoardControl: The Nunchuk Arduino implementation for the VESC: https://github.com/RollingGecko/ArduBoardControler
Berlin Custom Boards: All around DIY longboards: https://www.facebook.com/berlincustomboards/
Nordle   100 W
Post by Nordle » Aug 20 2015 2:50am
I'm unable!
Next questions:
IMG_0303 - Kopie.JPG (106.68 KiB) Viewed 3213 times
I can cut the PCB at the red line (with the beautifull scissor on top)?
Code: Select all
Transmitter has a potentiometer pin on Analog 3
-a is potentiometer pin that i connect to Analog 3 on Arduino?
-b is just +?
-c is gnd?
Do I need 2s Lipo to run my transmitter, or would it run on 1s to? Would be nice, cause i have a nice small 1s usb charger.
4:20 Noob Hubz! BLAZE it
..sry for dat poor english..
erwincoumans   100 W
Post by erwincoumans » Aug 20 2015 1:12pm
Yes, you cut at that line.
Usually the outer pins are ground and VCC (5V) and the center pin is variable. In my case, the ground was 'c' in your picture. If you have a multi-meter you could try out measuring the pins, just attach ground and 5V and measure the voltage on center pin and ground and move the potentiometer. Note that there are 2 potentiometers on that know, for X and Y axis. I only used up/down axis, not left/right.
erwincoumans   100 W
Post by erwincoumans » Aug 20 2015 1:14pm
RollingGecko wrote: Within the Arduino I think it would be nice to implement also Smoother from wiiceiver and other features. Post your ideas if you want.
Yes, it would be great to have an example of an Arduino communicating with the VESC over UART protocol. The large amount of examples, information and number of users of the Arduino eco-system is valuable. On the other hand, I like to learn more about VESC and ChibiOS, so both ChibiOS+STM32F4 and Arduino are useful to explore.
Marcin   1 W
Post by Marcin » Aug 20 2015 2:04pm
I love how we both went with very similar ideas when making our transmitters (I haven't seen this thread yet)
Definitely following this!
DIY Stealthy Longboard Build Log (Integrated batteries)
jacobbloy   100 W
Post by jacobbloy » Aug 20 2015 2:33pm
If any one needs wifi cases or joysticks for the wii I have them,
We could look at changing to the stm32f103 chip and you could run Arduino code,
Aslo I'm been talking to Austin creator of the wiiceiver and he has agreed to help make an Arduino receiver for the PCB that we have been working on so it is plug and play, basically we need to get the spi data from our PCB and get the wiiceiver to read it.
So if any one here wants to help with that it would be great.
Nordle   100 W
Post by Nordle » Aug 21 2015 8:12am
erwincoumans wrote:Usually the outer pins are ground and VCC (5V) and the center pin is variable. In my case, the ground was 'c' in your picture. If you have a multi-meter you could try out measuring the pins, just attach ground and 5V and measure the voltage on center pin and ground and move the potentiometer. Note that there are 2 potentiometers on that know, for X and Y axis. I only used up/down axis, not left/right.
I don't have a multi-meter. It's from an original Nintendo Nunchuck someone know's what I have to connect?
Nordel wrote:Do I need 2s Lipo to run my transmitter, or would it run on 1s to? Would be nice, cause i have a nice small 1s usb charger.
Nordle   100 W
Post by Nordle » Aug 22 2015 5:10am
Arduinos let me freak out!
Didn't touch them for some days and now the 2nd one seems to be broken-.- Chinese crap... I think i will order 2 new ones with original ftdi chips, hope this will solve one of my problems with that remote control.
This isn't fun anymore:(
Tombombadil1988   1 mW
Post by Tombombadil1988 » Aug 22 2015 6:09am
@erwincoumans Can you tell me how long the battery lasts on your Arduino transmitter side? Have you implemented sleep commands to save some battery?
erwincoumans   100 W
Post by erwincoumans » Aug 22 2015 10:47am
Tombombadil1988 wrote:@erwincoumans Can you tell me how long the battery lasts on your Arduino transmitter side? Have you implemented sleep commands to save some battery?
I haven't measured, but using the Arduino Nano + nRF24L01+ I would guess over 10 hours without power management, but I didn't measure it yet. I use an on-off switch and turn it off when not using it. This is using 2 tiny LIPO batteries of 3.7-4.2Volt each (1300mAH total).
There is also the Picoino Cell Arduino that you can plug an nRF24L01+ in, without soldering. It is even more power efficient. It is slightly too big due to the radio module sticking out on the wrong side. If it would be rotate 180 degrees, it might fit the Wii Nunchuck.
See pictures at http://www.amazon.com/Atmega328p-au-Mic ... B00WFM2N60
Post by Tombombadil1988 » Aug 22 2015 12:26pm
I don't mind the soldering so much, but I wouldn't like to damage the nunchuck for the switch. Do you maybe have a picture of the switch to see how you fit it in there?
erwincoumans   100 W
Post by erwincoumans » Aug 22 2015 2:35pm
Tombombadil1988 wrote:I don't mind the soldering so much, but I wouldn't like to damage the nunchuck for the switch. Do you maybe have a picture of the switch to see how you fit it in there?
Sure, here are the pictures. This was just a quick prototype and it won't win any beauty contest. The switch sticks out a little bit and I made a small space under the lid. If you prefer, you can cut off the sides of such switch, and then you don't need to modify the outer shell of the Nunchuck (Kama in my case). Note that the switch is not rigidly attached to the case, it is just sandwiched between lid and case. Also I had to cut away several small parts inside the Nunchuck Kama to make space for Arduino and batteries:
Post by Tombombadil1988 » Aug 22 2015 4:41pm
Thanks for sharing Erwin! I thought that the wireless nunchuks had a way to turn them on and off with an integrated switch or something. I just ordered this one, maybe I'll get lucky: http://www.ebay.de/itm/131226794705?_tr ... EBIDX%3AIT
Maybe we could extend the battery life by using one of the Arduino Sleepmodes: http://playground.arduino.cc/Learning/ArduinoSleepCode No idea how much that would help.
erwincoumans   100 W
Post by erwincoumans » Aug 22 2015 7:25pm
Tombombadil1988 wrote:Thanks for sharing Erwin! I thought that the wireless nunchuks had a way to turn them on and off with an integrated switch or something.
Yes, mine did as well, but the button was attached to the part of the original PCB that I had to cut away to make space for the Arduino...
RollingGecko   100 W
Post by RollingGecko » Aug 23 2015 4:58am
@ Nordei: What happend in detail?
Nordle   100 W
Post by Nordle » Aug 23 2015 8:20am
RollingGecko wrote:@ Nordei: What happend in detail?
I hit my Arduino, then I bleed a bit. :shock:
But seriously, after I received them I did:
-connect them to win7 PC and tried a few hours to get them work... without success
-connect them to Linux PC... now it worked, both arduinos light up when connectet to usb, but only one was detected by my PC (I upload the ''Blink'' sketch, and it worked). I assume the other one has a broke CH340 chip from what i read, told that to my Amazon seller and he will send me a new one.
-NOW a few days later I wanted to upload the Tx sketch but when I plug in my Arduino it Blinks random, some times nothings happens when I connect it. Looks to me like a loose connection.
Off Topic
Could I just connect my Nunchuck to my VESC with wires, just to check it out and do some settings while I'm working on Arduino Tx/Rx?
Moja Reeves   1 µW
Post by Moja Reeves » Aug 24 2015 2:01am
I have ordered a Nyko Kama nunchuck to use with my dual VESC setup for my dual drive board when it arrives, what additional parts do I need to buy and what is currently the easiest method of wiring and programming it to work with VESC?
Nordle   100 W
Post by Nordle » Aug 25 2015 8:55am
@Moja Reeves, that's described in the first post of this thread.
Today I powered my Arduino from an old PC psu while connected to my PC, he let out a bit of smoke and began to stink. I immediately disconnected everything. I feared the worst, but lol now it's working-.-
@erwincoumans
sry about my stupid question on the readme, everything is fine I'm just a noob (....a little less now)
