mjp8081
Almost done, I went out for a test ride today...I can't believe I ever doubted the power of these little RC motors--they need a bit of momentum to get going, but holy frock, the speed, and power up hills--its unbelievable. I followed all the info and advice from you guys and my 8S dual MTB runs perfectly. After a couple adjustments to the ESC's punch control and braking. I think I need to redesign the throttle trigger longer and with stronger spring for more control. After some final adjustments I will post my build--I think it will be interesting because I didn't go "out-of-the-box" and went with some cheaper but thoroughly researched components.
Q: What do you guys set your punch control at?
