Tacon Bigfoot Speed
garrettgajewski   1 mW
Tacon Bigfoot Speed
Post by garrettgajewski » Jun 27 2015 4:13pm
how fast could my longboard get with a tacon Bigfoot 160 motor with 2 zippy compact 5000mah 6s batteries?
psychotiller   10 kW
Re: Tacon Bigfoot Speed
Post by psychotiller » Jun 27 2015 4:32pm
What size wheels?
How many teeth will you have on your pulleys?
Are you running your batteries 6s or 12s?
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttp://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through http://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
verruckt   10 mW
Post by verruckt » Jun 29 2015 1:28pm
I run a Tacon Bigfoot 160 with a Castle XL2 ESC (8s max) on my Red Rock Boardshop LaGrange Setup.
I use a formula in Excel so I can plug in different parameters (motor kv / wheel size / gearing / voltage) and it will give me approximate speed in mph.
Here are some combos I have tried and have found the speed estimates to be accurate within 1 or 2 mph:
Motor-- kv-- battery-- wheel-- motor cog-- wheel cog-- ratio-- km/h----- approx. mph
Tacon 160-- 245-- 8s-- 76mm-- 14-- 28-- 2.00-- 51.94----- 32
Tacon 160-- 245-- 7s-- 76mm-- 14-- 28-- 2.00-- 45.45----- 28
Tacon 160-- 245-- 6s-- 76mm-- 14-- 28-- 2.00-- 38.96----- 24
I typically run at 7s and can go 28mph topped out on the flats. Any faster than that and wind resistance becomes an increasingly significant limiting factor. Also, I have no desire to go faster than 28mph. Most of my cruising is around 22mph. Flat out on 8s was way too high a pucker factor for me.
So to answer your question... with the above setup, if you were running your 2 6s lipos in parallel (effectively 6s), you would easily be able to cruise at 23 or 24mph.
Post your wheel size and gear ratio and I will plug in your numbers and give you an estimate.
CSN   100 W
Post by CSN » Jun 29 2015 1:48pm
Here is a calculator I ran across to try also.
http://toddy616.blogspot.com/2013/07/el ... lator.html
beto_pty   1 kW
Post by beto_pty » Jun 30 2015 1:29pm
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
okp   100 kW
Post by okp » Jun 30 2015 1:34pm
beto could be the Lance Armstrong of electronic long boarding !
beto_pty   1 kW
Post by beto_pty » Jun 30 2015 2:03pm
probably would fail doping tests as well..lol
