Estimating accelerations?
ProxRB   10 mW
Post by ProxRB » Jun 30 2015 7:28pm
I'm trying to estimate acceleration times, and as long as my math is right hopefully it'll be helpful for others too. Someone mind helping me double check the physics?
Question: how long does it take you to reach top speed if you weigh 200 lbs and are running a 6s LiPo setup with a Turnigy SK3 6374 motor (170 kV, 70 A "max current" quoted on HobbyKing, which I take to mean the stall current) and 83mm wheels, geared at 1.84:1 for a theoretical top speed of roughly 20 mph. First lets verify the gearing ratio gets us to the right top speed:
s_max = V_max * kV * gearing ratio * wheel circumference
s_max = 6 cells * (3.7 V/cell) * (170 motor rpm/V) * (1 wheel rpm / 1.84 motor rpm) * (Pi * 83 mm/revolution) * (0.001 m/mm) * (1 mi / 1609 m) * (60 min / hour)
s_max = 20 mph
Moving on, some unit conversions on the motor's kV constant tells us its torque constant:
kT = 1 / kV
kT = (1 volt / 170 rpm) * (W / A*V) * (N*m / s) * (1 rotation / 2 Pi rad) * (60 sec / 1 min)
kT = 0.0562 N m / A
Calculating the torque at the wheel is a matter of combining this torque constant, the motor's max current draw, and the gearing:
T_max = kT * A_max * gearing ratio
T_max = 0.0562 N*m / A * (70 A) * (1.84 wheel torque / 1 motor torque)
T_max = 7.24 N*m
Calculating the rate of acceleration is simple Newtonian physics:
a = F / mass = T_max / (wheel radius * mass)
a = (7.24 N*m) * (1 / 41.5 mm) * (1 / 200 lb) * (1000 mm / m) * (2.2 lb / kg)
a = 1.92 m/s^2
20 mph is 8.94 m/s, so at 1.92 m/s^2 it should take you (8.94 / 1.94) = 4.65 s.
All of this is of course assuming that we live in a frictionless, spherical vacuum yada yada...
Anything look glaringly wrong to you? Seems pretty quick, given that a reasonably fast family-car hits 0-60 mph in ~6 seconds. 5 seconds to get to cruising speed seems very resasonable, especially for such an underpowered design compared to what people here are building.
I'm guessing that my assumption that kT is constant with respect to motor speed could be wrong.
brent   1 W
1 W
Re: Estimating accelerations?
Post by brent » Jun 30 2015 8:12pm
kT's a constant, but your applied torque will fall as speed rises.
If your torque was always equal to T_max you wouldn't have a top speed. ;)
ProxRB   10 mW
Post by ProxRB » Jun 30 2015 10:07pm
Hah good point. What do you mean by applied torque, and quantitatively, how is it related to speed?
Pedrodemio   10 W
Post by Pedrodemio » Jun 30 2015 10:19pm
onloop   10 kW
Post by onloop » Jun 30 2015 11:47pm
I did some real world testing that you might be interested in, I also made a video and posted it on youtube back when I was doing lots of motors & drive train testing, check it out.
SKIP TO 4:10 To see test relevant to your post.
Let me explain more about what I am doing at the 4:10 mark, So I am basically trying to accelerate as fast as possible over 16 meters, I choose 16 meters because that's approximately how many meters it took until it felt like I was no longer accelerating, so in theory I had reached top speed. I suppose my reason for doing this was to see if one motor had better torque, because it is commonly said that lower KV motors have more torque, So my theory was more torque should equal faster acceleration & Based on the data I gathered this is true.
NOTE: I am not an Electrosciengineerologistion so my test methods, data & theories are done purely in the name of fun.
SEE THE TEST DATA: https://docs.google.com/spreadsheets/d/ ... sp=sharing
BUILD SPECS
DUAL REAR DRIVE (two different motors 245kv & 270kv)
6S battery
15-36 gearing setup (1:2.4)
Rider weight 200 pounds
83mm wheels
