Goped ESR upgrade - TURNIGY 6374 build
beetbocks
Re: Goped ESR upgrade - TURNIGY 6374 build
Post by beetbocks » Jan 22, 2017 6:44 am
SarDoX wrote:honestly - I have no clue how to make it charge without opening the board and disconnecting the circuit
2*4s lipos and in series, to charge them I need to plug them to parallel charging board, disconnect stabilizing wires from low voltage meter and also plug them in parallel charging board..
there will be so many extra wires and connectors...
Just a put charging port (deans connector for plus /minus and a 8s parallel cable). Then buy a 8s charger on eBay..
I've done the same on my scoots. Works perfectly. :)
https://endless-sphere.com/forums/viewt ... 35&t=55997
Or just fit a BMS (battery management system)
Keith_hill
Post by Keith_hill » Jan 23, 2017 3:39 pm
Hi!
Have a look at my build here: https://endless-sphere.com/forums/viewt ... 35&t=84487 I used a lower KV motor and 12S. I have geared 5:1 and can get 24.3mph reliably. I designed it to do 25mph so i'm pleased.
I'm not sure how you are getting on with gearing and speed but i have overcome a few problems with my build.
All the best!
Keith
