DIY Boosted inspired electric longboard
rutierut   1 mW
Re: DIY boosted inspired electric longboard
Post by rutierut » Oct 27 2015 7:12am
Wow this looks f*cking great, a more extensive build/guid would be great though!
okp   100 kW
Post by okp » Oct 27 2015 1:56pm
got an idea.. what about this to replace the oven grill
okp   100 kW
Post by okp » Oct 30 2015 3:14pm
hey, how many mm thick is the ABS you have used ? and what temperature is it melting ? I used 2mm ABS at 200° and for a complex form it's really hard to get the details
thanks!
torqueboards   100 MW
Post by torqueboards » Oct 30 2015 3:34pm
About 3mm is the average so it seems. I'd assume you'd want 1-2mm for a home built ABS setup with more detail and/or using kydex or something more pliable.
Wonder what OP uses though :)
DIYElectricSkateboard.com Electric Skateboard Kits
Squad   100 W
Post by Squad » Oct 30 2015 4:08pm
I used kydex about 1,5-2mm thick, the oven temp was about 180°C, so a little bit more than I usually set (150°C for knife sheets or gun holsters). And getting such complex shape requires using much force (I weight about 70 kg :D )
bbcane78   1 W
1 W
Post by bbcane78 » Nov 06 2015 6:35pm
I'm planning on doing a similar design, I have a quick question though. I'm using 83mm flywheels and I'm wondering what size belt pulley you used, I know the bore was 8mm but what is the diameter for the pulley as a whole?
Squad   100 W
Post by Squad » Nov 06 2015 7:14pm
bbcane78 wrote:I'm planning on doing a similar design, I have a quick question though. I'm using 83mm flywheels and I'm wondering what size belt pulley you used, I know the bore was 8mm but what is the diameter for the pulley as a whole?
The outer diameter of pulley is 46mm, it's 48 teeth HTD 3M 15.
bbcane78   1 W
1 W
Post by bbcane78 » Nov 09 2015 12:19pm
Would this setup work? Any recommendations if not or what could make it better?
2X http://www.hobbyking.com/hobbyking/stor ... 2400W.html
http://hobbyking.com/hobbyking/store/__ ... _UBEC.html
2X http://www.hobbyking.com/hobbyking/stor ... P_20C.html
http://www.hobbyking.com/hobbyking/stor ... UINE_.html
Also not so hot about the batteries, if anyone knows of any that are better, would have a longer life and more power in the same price range that would be awesome!
Squad   100 W
Post by Squad » Nov 09 2015 12:37pm
You need an ESC per one brushless motor, so if You're not buying "twin" esc (eg. Flier, APS) you're gonna need 2 of them for dual rear/diagonal set up. I can's speak any opinions about using boat ESC, don't have any experience with it (but from my short experience with eboard, the VESC seems like the best way to go). The motors are the same as mine. I use turnigy lipo cells because they are relatively cheap.
sl33py   10 kW
Post by sl33py » Nov 09 2015 1:07pm
bbcane78 wrote:Would this setup work? Any recommendations if not or what could make it better?
I would recommend you start a build/help thread so folks can guide you through this.
most everything looks ok except your ESC. You want a car ESC not boat or heli. The brakes (kind of important) don't work quite right on boat and heli ESC's. Dual 5060's should work great, but you will have trouble fitting the 5060's dual rear without spacers and wider trucks (i used Paris 195's on my dual 5060 (Torque's 5060 or 5065 - not positive any longer) setup. It was tight and spacers were needed (about 5mm ea side). Dual diagonal will work obviously.
Start a thread and we'll get you squared away!
GL!
bbcane78   1 W
1 W
Post by bbcane78 » Nov 09 2015 1:52pm
GL!
I started a thread https://endless-sphere.com/forums/viewt ... =7&t=74074
-let me know if you have any other help for me, I heard that the boat ESC works alright, not the best but this would be a cruiser for around campus mostly. If you know any other ESC's that would work for the two motors that is under 70-80$ please share them with me! thanks for the help!
makithepaki   1 mW
Post by makithepaki » Nov 13 2015 10:18pm
Hey i have some questions for you or if someone else could answer them.
1. where did you get that screen with the battery indicateur.
2. where did you buy poweron button
3. how did you setup on board charging
lox897   100 W
Post by lox897 » Nov 13 2015 10:56pm
That battery percentage screen can be bought off of ebay or aliexpress.
Squad   100 W
Post by Squad » Nov 14 2015 6:15am
makithepaki wrote:Hey i have some questions for you or if someone else could answer them.
1. Bought on ebay, as alreary answered
2. Search similiar power button as anti vandal latching switch (BUT in my build it's switching mosfets-based power circuit, it's NOT switch that simply closes the circuit and allows current to flow)
3. By simply placing charging and balancing port on the bottom of front enclosure, next to power button. No BMS on board, I use lipo charger with balancing function.
okp   100 kW
Post by okp » Nov 14 2015 6:27am
Hey Squad,
My wattmeter failed last week. I had the same battery % mesure component in my tool case, so decided to install it like you did :D
Do you think this device worth? Not tried it yet as yesterday night was the Parisian massacre 200m from my appartement. Crazy, especially because two days ago I was at the Bataclan for a night show/party.
Nice ride!
206monkey32   10 W
Post by 206monkey32 » Nov 14 2015 9:13am
Glad to hear you are alright okp. All the best to all the people of Paris.
Squad   100 W
Post by Squad » Nov 14 2015 9:40am
okp wrote:Hey Squad,
Nice ride!
I'm glad that You're ok, hope those ISIS bastards will get what they deserve...
This battery percentage meter is not super accurate, I'm using it only to know whether I have enough juice to ride or not. At approx 70% on display single cell voltage is about 3,8 V.
makithepaki   1 mW
Post by makithepaki » Nov 15 2015 12:13am
Hey sqaud so for the discharge connector was it connected like this
http://cdn.instructables.com/F80/D3M0/I ... .LARGE.jpg
Squad   100 W
Post by Squad » Nov 15 2015 7:29am
makithepaki wrote:Hey sqaud so for the discharge connector was it connected like this
Yup, exactly like that.
randyc1   100 W
Post by randyc1 » Dec 04 2015 1:08am
Beautifull build Squad !!
Newbie Questions:
I am amazed at how much speed you get on 7(S)!, have'nt seen many builds with these motors (very affordable aslo)
With these motors and your setup ,do have have plenty of torque ?
How does it accelerate from a complete standstill ?
Thanks !
Squad   100 W
Post by Squad » Dec 04 2015 6:17am
randyc1 wrote:Beautifull build Squad !!
Newbie Questions:
Thanks !
The torque is more than enough, it can accelerate from stand still, although usually I push to give it a little bit of speed and save batteries for later. I guess it would work a lot better with VESC instead of flier esc ( flier/APS ESC sometimes has problem with detecting both motors after turning on, and even with slower acceleretion set up it sometimes tries to throw You off)
randyc1   100 W
Post by randyc1 » Dec 04 2015 10:39am
Thanks Squad, btw, i was able to see only 1 pic ?,..the one with all your parts gathered on the floor for the build , where there many pics?
Squad   100 W
Post by Squad » Dec 04 2015 11:14am
randyc1 wrote:Thanks Squad, btw, i was able to see only 1 pic ?,..the one with all your parts gathered on the floor for the build , where there many pics?
Weird... :? the link is to the entire album with many photos from the build, I just checked and it works normally im my browser, maybe try another browser
randyc1   100 W
Post by randyc1 » Dec 04 2015 11:03pm
Your right , opened pics with google chrome !
WOW that is awesome detail!....Love your motor mounts , those motors would have never fit without that design.
...Im just getting into this hobby and want to build one as well. I'm not sure if the more i read the more confused i am ?
KV high or Low?? Gear Ratios?, wheel size? Will you be trying the VESC's ?
Anyhow,.. Great build !
Squad   100 W
Post by Squad » Dec 05 2015 2:54pm
Thanks @randyc1! Yup, the mounts needed to have thin motor mounting plates and despite that I had to add 6mm wide spacers on hanger axles to fit motors with 15mm wide belt. Generally the best KV is around 170 for 12S set up, gear ratio depends on the wheel size/motor KV/and battery pack voltage. Benjamin Vedder wrote guide for choosing right gear ratio and motor KV, it's somewhere here or on his site.
Anyway, I managed today to put together this bad boy :D Can't wait to electrify it! Trampa rocks the quality is top notch! With the bindings it feels just like being strapped to snowboard.
I'm gonna update this new build in this thread :D
