RideTheIon
If you're an openSUSE user and itching to configure your VESC, you'll find this post useful.
Compiling bldc-tool on openSUSE 13.X / enterprise SUSE 12 is fairly straight forward, once you get the Qt5 environment setup.
The biggest trip-up is that openSUSE's qmake only produces Qt4 makefiles.
Adding the option flag will only get you the error “Unknown option -qt=qt5”.
OpenSUSE has a separate qmake for Qt5 that is named qmake-qt5.
If you only install the Qt5 development packages below, your system won't even have the wrong qmake-program installed.
To run the tool, open a terminal as the non-privileged user and run the command “BLDC_Tool”.
Code:
## Compile BLDC-tool
# Add yourself to the dialout group to access the USB port of the ESC without being root
sudo usermod -G dialout $USER
# Do the rest as root
su -
# Uninstall modemmanager
zypper remove ModemManager
# Install dependencies
zypper install patterns-openSUSE-devel_qt5 libqt5-creator libqt5-qtserialport-devel libudev-dev
# Install git
zypper install git-core
# Get source and compile
cd /usr/src/
mkdir BLDC
cd BLDC
git clone https://github.com/vedderb/bldc-tool.git bldc-tool
cd bldc-tool
qmake-qt5
make
# Check binary and dependencies
readelf -h BLDC_Tool
ldd -d BLDC_Tool
# Install
cp -p ./BLDC_Tool /usr/bin/
# Leave su root
exit
