Hi Guys,
I would like some advice.
I've started my first build a build using Torqueboard's' V1 mounts on 195mm Paris trucks, for a dual rear drive.
When I tighten the clamp screws, I notice the ends of the mounts move outwards, probably because the hanger shaft of the trucks is not completely cylindrical.
This will lead to the motor axle not being 100% parallel to the truck axle.
How much should I worry about parallelism between the motor and truck axles ? What is your experience ?
Of course I could grind the hanger shaft down slightly to compensate, but I'd like to avoid if unnecessary.
Thanks for your help,
Tom
EDIT
I decided to make this thread my build thread after some of you put me on the right track with my question above.
Board: Loaded Dervish
Trucks: Randall R2 baseplates / Paris 165mm hangers
Wheels: 90mm Flywheels
I'm planning a dual rear drive with Enertion R-spec 6355 190kV motors, I also have two VESC's on order.
I'll need to sort out batteries soon, but I'll go with Lipo's because I already own 2 chargers/balancers.
Tom
EDIT
