I've found one more new Backfire board that has some really sick specs !!
Guys look at the specs !! To be honest it looks too good to be true. Not only it has dual hub motor - but look at the range. 20-30km of range !! Speed is also nice.
The board has some weight to it so actually it seems like they have added some
powerful battery there.
Motor power: 1500W*2
Max speed: 20-30km/h
Power: 1001-2000w
Voltage: >60v
Charging Time: 3-4hours
Range Per Charge: 20-30Km/h
Tire Size: 1050*240*140mm
Battery: 8000AH Lithium Battery
Net weight: 12kg
Some more detailed specs:
Motors: 2 integral hub motors (built into the wheel), soon available also with one wheel with an integrated motor
Hub Motor Specifications: Brushless direct current, 24 V and 750 W each, 85% efficiency
No load speed and current: 2620 rpm (revolutions per minute), 500mA
Top Speed: 45 km/h (28 mph) or 35 km/h (21 mph)
Forward and Backward driving: Backwards is even slightly more powerful
Battery Range: more than 20 km/12 miles, Lithium-Ion Battery (LiFePo4 )
Battery Charging Time: three hours, more than 500 times rechargeable
Regenerative Braking System (RBS): The battery will be charged while braking
Maximum user weight: 120-130 kg (264 lb to 286 lb)
Waterproof and sand protected: sealed design prevents sand or water entering in the motors or other parts
Deck Hardness: Stiff – designed for speed and stability
Deck Size: 1050mm*240mm*21mm
Deck Material: 6 layers of bamboo, 2 layers of fiber glass, 1 layer of sandpaper
Truck size: Custom design trucks, 200mm
Wheels: high performance PU, 78a, 83mm*51mm
Bearings: Ceramic balls in stainless steel casing
Remote controller: 2.4G communication system, 2 standard AA batteries
Has anyone tried it ? Or knows where to get it in the US ?
