Vedder's Nunchuk RF
chaka   1 kW
Vedder's Nunchuk RF
Post by chaka » Dec 02 2015 10:40am
We have some Nunchuck-RF PCB's in fabrication, should have them a week from now. I'll do my best to document everything during assembly and create a build guide. The Nunchuck has a 2 layer PCB and is a fairly simple build, a good project for someone new to smd with intermediate soldering skills.
The Nunchuk RF is a great piece of hardware, it provides a great platform for customizing the VESC with user programming, adding extra features to our builds.
Hardware: https://github.com/vedderb/nunchuk_rf_hw
Firmware: https://github.com/vedderb/nunchuk_mod
PCB's on OshPark: https://oshpark.com/shared_projects/GKeNqY7y
Tri Wing Screwdriver: https://www.google.com/search?q=tri+win ... A&dpr=1.09
Don't forget to send a little support to Ben for sharing this great project! http://vedder.se/2015/08/vesc-writing-c ... /#more-916
Image Image
torqueboards   100 MW
Re: Vedder's Nunchuk RF
Post by torqueboards » Dec 02 2015 11:27am
Awesome share :) subbed
DIYElectricSkateboard.com Electric Skateboard Kits
randyc1   100 W
Post by randyc1 » Dec 08 2015 2:47pm
Can i ask ,..is this something we need if we buy a Vesc ?
torqueboards   100 MW
Post by torqueboards » Dec 08 2015 3:38pm
randyc1 wrote:Can i ask ,..is this something we need if we buy a Vesc ?
You don't need this but this is a custom PCB for a Wii Nunchuck hack which you can use with the VESC.
Ryuudan   1 W
1 W
Post by Ryuudan » Dec 17 2015 6:56am
is this to hack a normal wired nunchuku into wireless?
sorry if it's a stupid question.
chaka   1 kW
Post by chaka » Dec 17 2015 9:27am
Ryuudan
Yes it is, I will have a little tutorial on the build here soon!
Ryuudan   1 W
1 W
Post by Ryuudan » Dec 17 2015 9:24pm
can it connect to 2 receivers? using one joystick to control 2 skates? like 1tx-2rx connection?
Im trying to build a handheld controller for my electric inline skates and I need one joystick to control both feet together.
would be possible to add this feature? :oops:
chaka   1 kW
Post by chaka » Dec 18 2015 11:56am
It is possible with spread spectrum transmitters/receivers but I would have to do some research to find your answer specifically as it relates to the nrf24l01.
Ryuudan   1 W
1 W
Post by Ryuudan » Dec 19 2015 1:37am
as far as I know the nRF24L01 cannot connect to multiple receivers, but it can connect to multiple (6 i think) transmitters.
nieles   10 kW
Post by nieles » Dec 19 2015 8:35am
i think your answer is in this post on the nordic devzone
https://devzone.nordicsemi.com/question ... ltiple-rx/
vedder   100 W
Post by vedder » Dec 19 2015 6:10pm
Ryuudan wrote:can it connect to 2 receivers? using one joystick to control 2 skates? like 1tx-2rx connection?
That should be possible with some minor modifications to the code.
Some of my projects: http://vedder.se
Support my open source ESC development with a small donation
dec   1 µW
Post by dec » Dec 22 2015 4:05pm
Does this use the original Kama receiver to interface with the VESC?
chaka   1 kW
Post by chaka » Dec 22 2015 4:12pm
dec wrote:Does this use the original Kama receiver to interface with the VESC?
No, it uses the widely available nrf24l01
dec   1 µW
Post by dec » Dec 22 2015 4:31pm
chaka wrote: No, it uses the widely available nrf24l01
Ah, cool. I guess that's app_nrf in the bldc code.
Wonder if I can fit one of these in the wired version of the Kama I bought by accident :)
torqueboards   100 MW
Post by torqueboards » Dec 22 2015 5:23pm
Most people will/can retro fit a wired nunchuck with this PCB. Nyko Kama's and other wireless Wii Nunchucks will be sold out soon since they aren't in production as much as before.
ryerson2019   100 µW
100 µW
Post by ryerson2019 » Jan 01 2016 11:34pm
Any word on availability for testing?
chaka   1 kW
Post by chaka » Jan 01 2016 11:46pm
We have a few more PCB's coming from OshPark. Will likely continue doing small runs while this is in development.
jacobbloy   100 W
Post by jacobbloy » Jan 02 2016 1:31am
Just make sure the you use the latest firmware as it is unstable and can be unsafe, and don't have any of the 2k resistors installed to set the address to 0, then very soon I'll push a git hub update to the code that will search and set the address according to what you have set your vesc address to, this way you can have 2 ppl riding at once with out soldering resistors.
dec   1 µW
Post by dec » Jan 02 2016 2:26am
jacobbloy wrote:Just make sure the you use the latest firmware as it is unstable and can be unsafe, and don't have any of the 2k resistors installed to set the address to 0, then very soon I'll push a git hub update to the code that will search and set the address according to what you have set your vesc address to, this way you can have 2 ppl riding at once with out soldering resistors.
Just to clarify - are you suggesting we should or should not use the latest firmware?
okp   100 kW
Post by okp » Jan 02 2016 2:53am
as recommended by Jacob, get the latest version; I will keep you posted once I get one in my hands for testing.
Dude   100 µW
100 µW
Post by Dude » Feb 14 2016 4:11pm
Hi Chaka,
I ordered the PCB from OshPark (thanks for providing the files) and currently I'm soldering the parts on it. Have you made any progress regarding a tutorial to get started? I would appreciate any help to get the RF connected to the VESC.
chaka   1 kW
Post by chaka » Feb 14 2016 5:22pm
Dude wrote:Hi Chaka,
Blasto has been making some headway on a tutorial over on vedders website. We'll push that info over here too. http://vedder.se/forums/viewtopic.php?f=15&t=75
Dude   100 µW
100 µW
Post by Dude » Feb 15 2016 10:17am
Thanks :D
