AngelDust|Trampa HolyPro 35|SK6374 168kv|E-TOXX|Dual VESC
okp   100 kW
Re: AngelDust|Trampa HolyPro 35|SK6374 168kv|E-TOXX|Dual VES
Post by okp » Dec 12 2015 6:14pm
Trampa + E-TOXX = New playground, let's ride!
Original video is from Eric R vimeo channel here : https://vimeo.com/148744565
Trbt555   10 W
Post by Trbt555 » Dec 13 2015 5:36am
Ok that's enough.
Please stop posting videos or I'll have to explain to my wife why I blew my christmas bonus on a mtb build...
Shred.
okp   100 kW
Post by okp » Dec 13 2015 7:31am
you should get it ! this thing is just awesome. The trampa deck is outstanding.
just did this for you when I saw your message this morning. 4200mAH is 19.60km distance with Multistar cheap 10C. Works fine. 8°C outside. Max Amps draw is 17Ah on 12S
This is "Le palais de tokyo", not that nice for filming.
And la Tour Eiffel in background
Enjoy !
Squad   100 W
Post by Squad » Dec 13 2015 7:37am
okp wrote:you should get it ! this thing is just awesome. The trampa deck is outstanding.
just did this for you when I saw your message this morning. 4200mAH is 19.69km distance with Multistar cheap 10C. Works fine. 8°C outside.
I think I underestimated range that I'll get out of my two 10Ah swappable battery packs with my build (I thought that about 20 km per one battery pack) :D It's gonna be awesome! (still waiting for the parts :cry:)
As always, great video and editing okp, go-pro gimball is super usefull!
okp   100 kW
Post by okp » Dec 13 2015 11:27am
Tires are inflated at 60PSI. Awesome speed. Rock solid and still huge fun to ride.
Multistar 10 are performing quite OK at this time. I will report back often. I remember when I had weak lipos in RC helicopters, sometimes I had less punch. What is difficult to measure here is the punch as 12S on a EMTB... even on a weak lipo... is enough punch to climb a hill ! Imagine on the asphalt.
I drew 5000mAH.. lipo was 3.11V; I had no more power on the batteries; Still trying to push on the throttle; no power at all. But that was normal :)
BEFORE CHARGING
Lipo 1
Lipo 2
AFTER CHARGING
5000mAH over 5200mAH with max capacity charging set to 95% ...with a startup boost value set at 0.030 on VESC (awesome value)
Enjoy!
okp   100 kW
Post by okp » Dec 16 2015 6:42pm
Merry Xmas ! For those who are wondering, this is not santa claus... but this is Les Champs Elysées !
okp   100 kW
Post by okp » Jan 17 2016 8:26am
well, I went DIY on the enclosures. Here are some photos of the progression.
I moved to the battery box
then I worked on the battery tray
a little thumbs up on my next build with the truncated :)
back to the tray
Now I added a nice finish on the raw boxes
stay tuned !
Pedrodemio   100 W
Post by Pedrodemio » Jan 17 2016 9:53am
Now i'm convinced that CF is the way to go. The foam you use is polyurethane?, and does the enclosure act as a faraday cage and block the radio signal?
Squad   100 W
Post by Squad » Jan 17 2016 10:03am
Nice work :) I decided to stick with UK boxes, they're waterproof and in my opinion it's great feauture in electric mountainboard. I'm still waiting for my new lathe to arrive, then when I find time I'll get to work and finish this project. In the meantime I'll be jelous about Your finished trampa project :D
okp   100 kW
Post by okp » Jan 17 2016 10:24am
@Pedro, no signal blocking as the antenna is just getting out 2 cm of the box
@Squad, thanks !
psychotiller   10 kW
Post by psychotiller » Jan 17 2016 12:03pm
This build is beautiful! :shock:
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttp://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through http://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
okp   100 kW
Post by okp » Jan 17 2016 12:12pm
thanks you psychotiller - much appreciated. This is all about learning from failure.
whitepony   10 kW
Post by whitepony » Jan 17 2016 2:20pm
really nice! if you are bored you should make a tutorial on your cfk vacuum skills! vacuuming really allows much sharper and well defined structures, love it!
okp   100 kW
Post by okp » Jan 30 2016 6:09pm
I almost forgot to keep you posted. Full DIY enclosures - board ready to ride is 11.2kg
WeeChumlee   1 kW
Post by WeeChumlee » Feb 01 2016 4:19am
Very nicely done okp, particularly like the enclosure for the VESCs. So neat and clean.
okp   100 kW
Post by okp » Feb 01 2016 1:59pm
thank you. I can't recommend trampa board enough. I really like how the deck behaves plus the titanium trucks are awesome in behavior. I wish I could get my hand on a XCARVE; I know people say it's not that accurate or well it's a low cost CNC carver.. but well that would fit my requirements :D
nowind   100 W
Post by nowind » Feb 06 2016 7:13am
Nice work my friend.
Your carbon skillz are pretty well!
You going straight forward to make the board more lightweight.
Can you confirm that your Multistar Lipos have around 640gramm per 6S-5200mAh Pack as Hobbyking listed?
I´m really trying to lower my boardweight too, build up a new Chaindriven one at the moment.
Using 5800maH ZippyCompact as 12S Config, but i´m still @ 12.5KG.
Ok if i to some rework on the Battery and Electronic Enclosures in a similar way as you do, what can i save? Maybe 600gramms ?!
I´m wondering how you get this low with 11.2KG, maybe i have to weight the Heelstraps, dont know what they have.
Less weight more power (-;
Keep on with your great build.
hang loose
jenso
melodious   100 kW
Post by melodious » Feb 07 2016 11:08am
Such a beautiful build. I need to progress to eMTB.
What range are you getting on battery/controller/motor setup?
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
okp   100 kW
Post by okp » Feb 07 2016 11:39am
thanks, I should have posted the specs earlier in the thread.
4200 mAH / 8°C ... 19,60 km
I have finished the build with the attachement of the enclosure
ElectricGod   1 GW
1 GW
Post by ElectricGod » Feb 10 2016 8:28pm
WANT!!!
Awesome build! I'm drooling.
XB-502: viewtopic.php?f=10&t=83302&p=1222730#p1222730
Currie scooter: viewtopic.php?f=35&t=83830&p=1227407#p1227407
Benjamin Franklin - "Any fool can criticize, condemn and complain and most fools do."
okp   100 kW
Post by okp » Feb 11 2016 4:36pm
thanks you. I will be featured saturday night on a french/german legendary tv show, proudly riding my trampa holypro deck and showing how my revisited vanguard is build in DIY :D
nowind   100 W
Post by nowind » Feb 14 2016 10:00am
Hey Cedric.
Saw you on ARTE on Saturday.
NICE
http://tracks.arte.tv/de/gibt-es-skateb ... elektrisch
Greetz
Jenso
Nordle   100 W
Post by Nordle » Feb 14 2016 11:48am
Where do I get these custom Nunchuck pcb boards?
4:20 Noob Hubz! BLAZE it
..sry for dat poor english..
okp   100 kW
Post by okp » Feb 21 2016 12:27pm
lighter = awesomeness !
climb test on Multistar 10C.. seems to lack a bit of power. I will move on the boost to 0.020
whitepony   10 kW
Post by whitepony » Feb 21 2016 1:56pm
huh, that was getting REALLY slow in the end instead of just slipping tires. do you think this could be a consequence of can bus linked vescs with traction control enabled? would like to see this again without traction control, cause the 6374 engines should just immediately break loose the wheel! :o
