Simonk firmware for E-skate board.
june2005   100 µW
100 µW
Post by june2005 » Dec 14 2015 12:13am
Is there anyone who want very cheap ESCs for skate board with airplane ESC?
I started a year ago and have some results on this.
It took almost two month to understand simonk firmware and one month to modify firmware.
arielrossolato   10 mW
Re: simonk firmware for E-skate board.
Post by arielrossolato » Dec 14 2015 7:32am
Tell us more :-)
june2005   100 µW
100 µW
Post by june2005 » Dec 14 2015 6:07pm
I added youtube link.
Simonk firmware only support drag brake.
but with this modification, you can control brake with throttle stick.
ESC in movie clip is Redbrick 70A ESC which was sold in hobbyking and price was lower than $20.
It support 6s li-po battery. so if you are moderate e-skateboard user, you can use this.
NTM5060 motor and SK-5065 motor are tested.
maybe you can imagine proposinal control by listening brake sound
june2005   100 µW
100 µW
Post by june2005 » Dec 14 2015 7:10pm
arielrossolato wrote:Tell us more :-)
NyOliver   10 W
Re: Simonk firmware for E-skate board.
Post by NyOliver » Dec 20 2015 2:40pm
That's seems amazing. Strong brakes are the only reason budget builds don't use plane esc.
sl33py   10 kW
Post by sl33py » Dec 21 2015 3:15pm
very cool!
How does it work with an actual load (like a human sized one!)? I've had a couple ESC's that seemed to break well until i was on them and then they just gradually slowed down (not fast enough) under full brakes.
How do you adjust braking power (50/60/70%?) and via what? USB programmer or LCD programming card?
Love to have more options - i've used Simonk on old quadcopter for years!
NyOliver   10 W
Post by NyOliver » Dec 26 2015 6:39pm
Update?
june2005   100 µW
100 µW
Post by june2005 » Jan 03 2016 6:36pm
thanks
that's why I started this project.
but there are some cheap car escs lately.
june2005   100 µW
100 µW
Post by june2005 » Jan 03 2016 6:39pm
sl33py wrote:very cool!
I have tested for MBS mountain board with 5065 380kv dual motor.
it works well even in the hill. and what I tested was just 70A escs.
for test I didn't implemented options.
I activated braking power to 100% so if user want to reduce braking power, user must change setting of controller.(ex EPA)
june2005   100 µW
100 µW
Post by june2005 » Jan 03 2016 6:46pm
these are list that I have tested.
- mistery firedragon 100A
- Redbrick 70A with blue pcb.
- Redbrick 125A with black pcb.
- Redbrick 125A with red pcb.
- hobbyking SS 125A
Notice...
These Escs are cheap escs, so they cannot endure high pulse current.
If you ride skate board midly, you can use thses.
I also tested with MBS mountain board with 5065 380kv motor, ratio is 5:1
I ride 40km(24mile) without rest, and it works until now.
the most valuable thing in this project is we can use high voltage airplain escs for e-skate board!!!
torqueboards   100 MW
Post by torqueboards » Jan 03 2016 7:11pm
Great news.. Glad someone worked on this :)
With the VESC getting much cheaper it makes more sense to spend the added $30-40 bucks.
DIYElectricSkateboard.com Electric Skateboard Kits
NyOliver   10 W
Post by NyOliver » Jan 05 2016 7:56pm
Can you post the test version for others please?
june2005   100 µW
100 µW
Post by june2005 » Jan 08 2016 1:04am
NyOliver wrote:Can you post the test version for others please?
these are my first test in MBS comp mountain board.
I used twin 70A ESCs, 5065 380kv motor, 5s lipo battery.
I can clime most of uphills without burning ESCs.
june2005   100 µW
100 µW
Post by june2005 » Jan 08 2016 1:08am
torqueboards wrote:Great news.. Glad someone worked on this :)
yes.. you are right.
VESC is getting cheaper.
but if I use Redbrick HV 80A esc, I can run motor with 10s battery and the cost is only $50.
ignas   1 µW
Post by ignas » Jan 12 2016 9:02am
Excellent work! Great for value builds.
Will you share the modified source code?
june2005   100 µW
100 µW
Post by june2005 » Jan 27 2016 6:26am
ignas wrote:Excellent work! Great for value builds.
If you want, i can share.
My email address is yj04.choi@gmail.com
Vanarian   10 kW
Post by Vanarian » Jan 27 2016 11:13am
Your work is awesome, I have a Danish friend who wants to build himself a DIY board for commuting to his high school on a reasonable budget and he is amazed at how cheap plane ESCs can be!
-+AT-One project : electric inline skates - no remote, hub motors, one frame for various wheel sizes & quasi-universal boot mount
Rollo Ergo Sum!
iscle   10 µW
10 µW
Post by iscle » Feb 19 2016 1:54pm
hi, i've sent you an email 20 days ago asking for the firmware and i haven't received anything yet.
If possible, can you upload it to mega or mediafire or a hosting and post the link? i'm very interested...
thanks
CptanPanic   10 µW
10 µW
Post by CptanPanic » Aug 04 2016 8:35am
Anything new with this?
NyOliver   10 W
Post by NyOliver » Oct 26 2016 8:42am
Not that I can see,
However, Simonk does support Car signals, braking and reverse.
Forward and reverse commutation supported, including RC-car style reverse-neutral-forward PWM ranges, with optional braking
https://github.com/sim-/tgy
Here's a 6s Esc for $10, which could be suitable for a penny board, going under 10 or 15 miles an hour,
http://www.hobbyking.com/hobbyking/stor ... _Opto.html
600w, continuous is not a small tiny amount of power, and of course if you had two of them and two motors, 15 miles an hour and hills should be possible, for a budget.
harryjosh   1 µW
Post by harryjosh » May 07 2019 4:39am
Electric skateboards basically do use RC motors. This ESC offers a max speed of 25 mph on HyperOutdoor skate Boards. You may need to buy a remote for this ESC. Buy the MR30 adaptor to make this ESC compatible they've got the price down about as far as possible.
