VESC - NRF implementation losing connection
daves22   1 µW
Post by daves22 » Dec 23 2015 5:12pm
Hi, Ive recently received my VESC and proceeded to wire it up with a custom nunchuck and a nrf24l01 receiver
Unfortunately the throttle seems to cut out when I try to accelerate fast making me nearly lose my balance, this especially happens at higher speeds
Does anyone know what might cause the issue? Moving the NRF receiver further away from the VESC has improved the situation but it's already 20cm away from it. I also added a capacitor to the NRF receiver
I did not have this problem using a PPM receiver
Dave
vedder   100 W
Re: VESC - NRF implementation losing connection
Post by vedder » Dec 23 2015 7:52pm
Are you using a receiver with PA such as this one?
http://www.ebay.com/itm/1PCS-NRF24L01-P ... Sw5VFWKapJ
They have been working perfectly for me, but the receivers without the amplifier and just the PCB antenna haven't been working that well for some reason.
Some of my projects: http://vedder.se
Support my open source ESC development with a small donation
daves22   1 µW
Post by daves22 » Dec 23 2015 8:27pm
Thank you for your reply! I am indeed using the pcb antenna version, can't really use the PA one due to space constraints.. Any idea what i can try?
Regards
vedder   100 W
Post by vedder » Dec 23 2015 9:13pm
The best thing I can suggest is to try to make some space. You can take the antenna apart or use a smaller antenna. You can also remove the sma connector from the PCB and solder a small antenna cable with a smaller 2.4ghz antenna directly to the pcb.
okp   100 kW
Post by okp » Dec 24 2015 3:45am
I have been riding the NRF with the antenna for more than 500km in Paris downtown and it's really fine. No interference or whatsoever.
daves22   1 µW
Post by daves22 » Dec 24 2015 7:40am
Alright, thank you for your help
I've ordered the PA version of the RX/TX. I'll probably remove the antenna wire from the rubber enclosure and stuff it in my board somehow
