Hi,
I have a setup with this parts:
https://endless-sphere.com/forums/viewtopic.php?f=35&t=56809
I wonder if i can use a simple on/off switch like this:
http://www.kjell.com/se/sortiment/e...gomkopplare/strombrytare-250v-6a-1-pol-p36092
to turn the power on and off. I will use it together with a momentary switch that connects to the negative pole through the resistor already soldered close to the ESC.
http://alienpowersystem.com/shop/e-board-kits/aps-120amp-3-2kw-single-motor-e-board-diy-kit/
Will this work or will the high currents make the on/off switch burn?
