CARVON V2 Dual Hubs on 12s Hill Climb Video
LEVer   10 kW
Post by LEVer » Mar 04 2016 12:17pm
From one of my riders.
Hill resized.jpg (56.46 KiB) Viewed 1515 times
RAd board!
dual Hubs 12s.jpg (32 KiB) Viewed 1515 times
okp   100 kW
Re: CARVON V2 Dual Hubs on 12s Hill Climb Video
Post by okp » Mar 04 2016 1:59pm
awesome ! good job jerry.
SteveS   100 mW
Post by SteveS » Mar 04 2016 2:18pm
Very nice. What's the grade on that hill?
LEVer   10 kW
Post by LEVer » Mar 04 2016 2:36pm
okp wrote:awesome ! good job jerry.
Thanks bro! Although board and video is not mine. I can't wait to see YOUR video. :wink:
I'm not doing much riding lately, too busy trying to build a Mini Cruiser like Rik's, http://runplayback.com/heres-a-manual-o ... skateboard
SteveS wrote:Very nice. What's the grade on that hill?
He wrote "5-6 degree hill half throttle 19.7 mph" on the YT description, so I guess 10%? It looks steeper than it is but the speed was pretty nice.
SteveS   100 mW
Post by SteveS » Mar 04 2016 3:25pm
LEVer wrote:[He wrote "5-6 degree hill half throttle 19.7 mph" on the YT description, so I guess 10%? It looks steeper than it is but the speed was pretty nice.
Thanks, I overlooked that description.
torqueboards   100 MW
Post by torqueboards » Mar 04 2016 5:05pm
Sweet! Looks great.. That means the 15% incline is definitely doable.. What was his rider weight? What ESC's is he using? Guess, I gotta get mine setup now!
DIYElectricSkateboard.com Electric Skateboard Kits
LEVer   10 kW
Post by LEVer » Mar 04 2016 6:04pm
torqueboards wrote:Sweet! Looks great.. That means the 15% incline is definitely doable.. What was his rider weight? What ESC's is he using? Guess, I gotta get mine setup now!
He's using your 12s ESCs! :D
Rider's weight is 185 and board is 18 lb.
torqueboards   100 MW
Post by torqueboards » Mar 04 2016 10:04pm
awesome! I'll get my dual hub motors collecting dust and start playing with them.. :mrgreen:
appelton   1 mW
Post by appelton » Mar 05 2016 10:37am
Question to CARVON guys ! - how difficult is it to modify YUNEEC EGO with your hub motor wheels ? I have nothing to do with electronics but I assume that I would have to also change yuneec ESC aswell ? I don't want to make a board from scratch. It's too much for me. But I consider buying good board and later modifying it.
Is there any tutorial or video that could help me ? I consider buying a board with good battery in it and later modifying it by adding hub motors. All I need is good RANGE and some nice speed - not too fast like BOOSTED and not too slow like Yuneec.
LEVer   10 kW
Post by LEVer » Mar 05 2016 1:36pm
For the E-go, you would need to modify almost all of the electronics whether you go hub motor or with a new belt-motor. They have their whole system integrated and they really don't want it messed around. I've experimented with the Backfire/Melonboard/Lecdec board and replaced the belt-motor with a Single hub, but the braking is weak unless you can put a VESC in there and modify the braking curve. In the end, it will be easier and better building one yourself.
All the parts for building a complete board are available, you would just need to connect them. Check out http://runplayback.com/how-i-built-a-diy-eboard
LEVer   10 kW
Post by LEVer » Mar 05 2016 2:41pm
More videos from his Youtube channel. This is a very good example of how to ride when there are pedestrians around.
