Hey folks,
I just gave a try to hub motors and compared it to a single drive system and share with you my feedback. I am running a 12S MaxAmp 150C, so the battery is able to deliver more than anything can be expected. I got a single hub from Carveon and I like to say that this is a masterpiece of art. Congrats Jerry for the job. I first tried 10S3P with the Hub... but well ... that's not interesting, getting up to speed is ... slow. So I moved to a 12S Lipo immediately!!!!
BLDC SINGLE DRIVE RSPEC 6355 190kv 14/32T
12S - motor max 80 / motor regen -60 / batt max 60 / batt min regen -20 / startup boost to 0,050
- 518.7mah=> 3.65 km - 48.8V
- 985.7 mah => 5.84km - 47.7v
- 1538.7 man => 10.80 - 46.7v
=> charged cap : 158.6mAh
BLDC SINGLE HUB CARVEON v2 / 90mm
BLDC - Min ERPM Limit : 600 (instead of 900) / ERPM Limit 50 (instead of 150)
- 838,3mah => 6,43km - 47.8V
- moved startup boost to 0.060
- 1976.2 mah => 15.73km - 46V
- charged cap : 111.4mah
As a conclusion, I will continue my tests but maybe it's me... I just don't get the hype around hub motors.... as single drives are WAY more efficient according to this early test... just waiting to try and try ! F.O.C even if its still new is awesome on a hub motor, because you ride silently... nevertheless I also don't get the hype about FOC... not really convinced that this is better than BLDC for our electric skateboards (less punch, less brake = less security)
I tried also a single Tacoon 245kv in BLDC mode with 14/32T... it's way better than the hub... really fun when you get up to speed.... but I still prefer without any hesitation a single RSPEC 190kv on 12S (I don't have any auctions at Enertion!)
Enjoy!
The ride is pleasant, punchy - of course you don't go hills, or at least small hills with speed. Brakes acts efficiently (of course not as well as a dual rear) nicely like an elastic feeling. I like that. Getting up too speed is quite fast. Sound in BLDC is not that loud. I definitely prefer dual rear but single on a short deck is really fun
The ride is average (but only when you get at speed)- which is were you start to have a little fun)... otherwise starting from 0 is SLOW (I mean really really slow) and even if you push by foot... it's still slow as hell... it's noisy when you ride even if you get used to that. Hill climbing is really a pain, you don't even go there, even small hills. I like the hub look, even if it's outside the wheels, the job is pretty impressive.
I gave a try yesterday to FOC mode... with many settings and man... you don't want to ride it in town... almost no braking... and acceleration is slower than slow !
Enjoy!
