so i found this e -board instructable thats using the same motor as I bought... so i figured i might as well get all the same electronics components that he uses...
http://www.instructables.com/id/Electric-Skateboard-V40-the-Banana-Board/step2/Materials/
but anyway... i searched on ebay for the ESC he listed in the materials list... and i scrolled down a bit and found this
http://www.ebay.com/itm/Hobbywing-Quicrun-WP-8BL150-150A-Waterproof-Brushless-Motor-ESC-RC-1-8-Car-US-/222047544079?hash=item33b310a30f:g:SQwAAOSwr7ZW34xF is this for real!??!
and also im not very knowledgable about the specs on these things so the other question would be if this has the same capabilities as the one the guy in the instructable used which is basically just a EZRUN/HobbyWing 150A-PRO Brushless ESC... if not are there any cheaper options that would be able to do the same job as the ESC that the guy in the instructable used without any overloads... etc whatever happens when the specs on your speed controller are not appropriate for what is needed...
im going for two 3S batteries if that matters... honestly you can jsut see the electrical schematic in the instructable for what i plan to do...
