Montiey
- Joined
- Dec 10, 2015
- Messages
- 89
So I got my board finished, and went out for a test. Immediately, the throttle was jittery and the Nunchuck constantly disconnected and just did't behave well. I found that by holding it next to the receiver, the problems went away for the most part. This is probably my fault for mounting it under the VESC, so its signal is blocked. Anyway, just today I was testing the range to see if I could reproduce the results, and all of a sudden I got the blinking pink light. While moving, I applied the brake and the motor slowed, then I must have reversed it to go back across the room, since the motor cogged a bit (braking is nice and smooth).
I immediately plugged in a USB cable and got the faults list from the Terminal tab:
I've tried re-uploading firmware hw_410_411_412 (VESC HW2.14), and the only thing that changed was that I had to pull the power for the nunchuck to be recognized (and / or) the fault to start again.
The motor seems to receive absolutely zero power under any of the circumstances I've tested it with, but I can still see the current and stuff changing in BLDC tool.
Any suggestions for what to try?
I'm a bit worried a broke it again, but I'm not sure how I could have.
Code:
Fault : FAULT_CODE_DRV8302
Current : -0.1
Current filtered : 0.2
Voltage : 31.77
Duty : 0.01
RPM : 0.3
Tacho : 4
Cycles running : 3
TIM duty : 425
TIM val samp : 215
TIM current samp : 25600
TIM top : 50770
Comm step : 4
Temperature : 26.74
