charles2317
- Joined
- Apr 29, 2016
- Messages
- 2
Question 1:
How well do these calculations hold up for real world e-longboards with a load?
I recently ordered the 149kv SK3 from Turnigy and the calculations @ 10s with a gear reduction of 3, give you still decent speeds (13m/s -> 29mph). But how do these numbers work out in the real world? I only weight about ~140lbs but in general that is still a lot of mass, large inertia.
Question 2:
Is it still safe for the motor to run it at lower voltage than what it's rated at? I'm pretty sure I've seen it is fine, but let us say HobbyKing says max 12s, so 6s would be fine too, just lower RPM?
Thanks!
Question 2:
Thanks!
