1st Eskate Build -Drop thru -6364- Outboard.
randyc1   100 W
Post by randyc1 » May 07 2016 8:34pm
After being inspired by Amazing builds from people like -nowind, Squad,and whitepony,...
I decided to try my own .
-Funbox deck (modified)
-Paris195's
-sk3 6364 245kv
-Ollinboard's VESC + Badwolf gt2b
-DIY:
- motor mount
-18650 10s4p
-abs enclosure
Got inpiration for my mounts(made 2) from Squad's +Nowind's beautifull mounts !!. Incorporated a little of both in mine .
psychotiller   10 kW
Re: 1st Eskate Build -Drop thru -6364- Outboard.
Post by psychotiller » May 07 2016 9:32pm
Great looking build!
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttp://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through http://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
Ballistrophobia   10 mW
Post by Ballistrophobia » May 07 2016 9:47pm
Looks great! I'm currently researching for my own build. What size pulleys did you end up using and how did you attach the wheel pulley to the drive wheel?
randyc1   100 W
Post by randyc1 » May 07 2016 10:06pm
Thanks psychotiller !
Motor pulley 15t, ,...wheel pulley 36t which came with the bolts that go through Kegel wheel .
whitepony   10 kW
Post by whitepony » May 08 2016 6:14am
hehe, you really took your time :D
looks really awesome to be honest, reminds me a little of the evolve bamboos with the motor pointing away from the rear (cause of drop through i guess?), the grip tape stripes and the natural wood looks! will you upload pictures of the battery building and some abs enclosure close ups too? enclosure looks really great, extremely slim profile, looks so slim that im wondering if you sunk the battery slightly into the board? how much flex does the deck have?
awesome how low it is to the ground, thats really the beauty of a drop through setup. :)
Squad   100 W
Post by Squad » May 08 2016 6:32am
Awesome @randyc1! Really clean and nice build! At first I started looking at the photos, and motor mounts drew my attention, I thought "hmm... they look kinda familiar", then I read Your post. I feel honoured to inspire someone :wink: My first build (boosted look-a-like) is currently out of order, as my lipo pack died some time ago, but I have a plan, to revive it, and make it even better. I ordered 40 18605 LG HG2 cells yesterday from aliexpress for 4,5$ each with shipping (I consider this as bargain) and from my calculations 10S4P (it will be 12Ah!!!) pack should perfectly fit in my battery enclosure. I'll also mill new motor mounts, as I scratched hell out of the old ones, and will anodize them black.
randyc1   100 W
Post by randyc1 » May 08 2016 12:09pm
Thank you whitepony and squad !
I did not sink in ,..ABS is around 2mm thick so in total Enclosure is 25mm and 31mm thick at end for Vesc, wires ect...
This leaves me with 2.5"(63mm) and 2.25"(57mm) clearance at thick end.
randyc1   100 W
Post by randyc1 » May 08 2016 12:20pm
Made the 6061 Aluminum section of my motor mount using an ordinary Router with a spiral cutting bit using WD-40 as lub.
Squad   100 W
Post by Squad » May 08 2016 2:48pm
WD-40 does magic when working with aluminium! I wouldn't be able to cut material out of my 15mm thick 7075 motor-mounting plates with a hacksaw without this stuff!
whitepony   10 kW
Post by whitepony » May 08 2016 2:51pm
really nice case, how did you make it? do you have a vacuum table? your board isnt probably very flexy? I ran into the problem of a semi-flexy deck vs. mounting holes in the enclosure - quite some strain on the enclosure at these points. it also seems to fit the surface of the board really well hmm :o
did you solder your 10S4P battery or spot weld? which cells did you use?
randyc1   100 W
Post by randyc1 » May 08 2016 3:52pm
Squad:
I wanted to get my mount CNC'ed but was way to expensive so decided to try with Router ,... was suprised i how well it went, table saw and a 60t blade went well also !
The 3mm stailess steel part was made using a 35 ton punch were i work. It originally looked very basic , more like pic before i reshaped it.
Are you going to cnc your new mounts squad ?
Whitepony:
Yes i built a very basic vacum table with a slight curve but should have made it more pronounced.
My oven Lol,.. a Cardboard box lined with alum foil heated by a 1500w heat lamp , it actually got up to over 300°f !!! , did this by Garage door, had hose ready just in case . Took me 3 tries to get it right !!
And yes i bought a spot welder from Riba and Tesla cells from okashira.,...will show in next post.
Squad   100 W
Post by Squad » May 08 2016 5:03pm
randyc1 wrote:Are you going to cnc your new mounts squad ?
Nope, once again the hard way, rotary table, vice and my mill :D
whitepony   10 kW
Post by whitepony » May 09 2016 12:30am
wow, thats awesome, why didnt xou post it in the first place?!
with tesla cells you mean these low drain panasonics? :?
randyc1   100 W
Post by randyc1 » May 09 2016 12:48am
whitepony wrote:wow, thats awesome, why didnt xou post it in the first place?!
I'm not quite sure, but yes I think they are from Panasonic and maybe (Panasonic-Sanyo), Okashira said they were very similar to the Sanyo GA's but with slightly less capacity, i think 3200mAh.
...I might try your sinking in trick ?,... because of concave shape of board , edges of enclosure are slightly tight, maybe Routering center out around 2-3mm will relieve a little pressure from center. Board is pretty stiff also, so might help a little like it did on yours ?
whitepony   10 kW
Post by whitepony » May 09 2016 1:17am
yea, maybe - if you cant model the board well you can always flatten the boards roadside to make it easier for you :)
my main issues came from from actual flexing - it was pretty hard on the enclosure. you left a pretty small lip around the enclosure for your mounting holes like I did on my first enclosure. hope it wont wear itself out like mine! :?
but you got the tooling now, easy to produce new enclosures and iterate :)
randyc1   100 W
Post by randyc1 » May 09 2016 2:05am
True about the enclosure stress.
Was thinking of maybe slotting the enclosure holes a bit to allow movement and loctiting the screws slightly loose ??
whitepony   10 kW
Post by whitepony » May 09 2016 3:33am
thats what sl33py suggested too, but then you probably end up with rattling. to avoid that, you'd probably have to use some tape between board and enclosure then, maybe neoprene/rubber band of double side adhesive. nothing is more annoying than rattling tbh :x
I made the bond of board/enclosure very strong now with screws with wide washers, lots of pressure and strong double adhesive tape between these board and case. the enclosure is now FULLY involved in flexing (which stiffens the whole thing noticeably). think there are just 2 ways - either you make it quite loose and account for the flex or you make it seriously strong and stiff!
okp   100 kW
Post by okp » May 09 2016 6:21am
good job ! solid skills here :D
randyc1   100 W
Post by randyc1 » May 09 2016 9:43am
I had planned on using this stuff that i bought at dollar store, it's this (anti slip) kinda rubbery material. Would work as kind of a buffer and stop battery from sliding around if were loose. I did'nt use since i have a tight fit as it is.
randyc1   100 W
Post by randyc1 » May 09 2016 9:54am
18650 batteries.from a Tesla.
mccloed   100 W
Post by mccloed » May 09 2016 11:34am
This is an awesome build! So streamlined. Looks like one of my builds but better! Nice work @randyc1!
sl33py   10 kW
Post by sl33py » May 09 2016 12:07pm
beautifully done. Some solid skills there to make your own mount and batteries!
randyc1   100 W
Post by randyc1 » May 09 2016 12:39pm
Thank you guys , I appreciate !.
randyc1   100 W
Post by randyc1 » May 10 2016 12:38am
okp wrote:good job ! solid skills here :D
Thanks!,.. love your "GT2B CUSTOM CARBON" !!
Hummina Shadeeba   1 MW
Post by Hummina Shadeeba » May 10 2016 1:07am
I really like that mount. I guess the plate is steel. Never see that. Nice and thin but still looks strong
