Motor-Mount-Holes Standard
notger   100 W
Post by notger » Jun 07 2016 12:25am
Hi,
I'm totally new to e-skateboarding.
So first i'd like to say hello.
I have quite some experience with ebike builds though.
A problem that we ebike mid-drive guys have is a standard mount of motors (wich is always solveable for sure)
And it seems that same is true for motors used on e-skateboards.
so until now i came across 25, 28, 30, 32, 44, 44.1, and many different mounting hole distances.
sometimes ordered across, sometimes in a third of a circle.
What are your experiences with motor mountin hole distances.
My main interest is in 50-63 diameter motors >2kw.
like the enertion, alien-drive systems motors or the turnigy sk3, cause those seem to be the most used motors on e-longboards.
So please share your distance expereinces, that we/i can collect some reference here.
greets
notger
chuttney1   100 W
Re: Motor-Mount-Holes Standard
Post by chuttney1 » Jun 07 2016 8:04pm
I use Turnigy Sk3 6374 uses 32mm bolt holes as said on their website.
psychotiller   10 kW
Post by psychotiller » Jun 07 2016 9:03pm
chuttney1 wrote:I use Turnigy Sk3 6374 uses 32mm bolt holes as said on their website.
If you measure diagonally those are 44mm hole spacing
50mm motors measured diagonally have 30mm hole spacing
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttp://endless-sphere.com/forums/viewto ... 35&t=59259
6" Pneumatic Tire Drop Down/Drop Through http://endless-sphere.com/forums/viewto ... 35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
s28400   100 W
Post by s28400 » Jun 07 2016 9:44pm
I made a 3D model of the APS 6355 230kv motor. You can download it here: https://grabcad.com/library/alien-power ... er-motor-1
My Project Site: https://www.radicalcreation.com
Science may set limits to knowledge, but should not set limits to imagination.
nowind   100 W
Post by nowind » Jun 07 2016 11:45pm
Tunigy SK3-6364 : 44mm Pitch circle, 4xM4
Tunigy SK3-6374 : 44mm Pitch circle, 4xM4
Alien APS 6374 : 44mm Pitch circle, 4xM4
Enertion R-SPEC 6372 : 44mm Pitch circle, 4xM4
Leopard 8072 : 59mm Pitch circle, 4xM5
Greeez
Jenso
notger   100 W
Post by notger » Jun 08 2016 4:11am
thats a pretty weired way to describe the hole distances in my opinion.
cause 32mm would mean 44 in diagonal right ?
thanks guys, now its clearer to me.
i could not really believe that alien would just have 30mm in diagonal like stated on the technical drawing here.
http://alienpowersystem.com/shop/brushl ... kv-3200w/#
so thats a mistake from their side right?
thanks
notger
notger   100 W
Post by notger » Jun 09 2016 3:19pm
s28400 wrote:I made a 3D model of the APS 6355 230kv motor. You can download it here: https://grabcad.com/library/alien-power ... er-motor-1
thats nice, but for some reason i cannot open it in Autodesk inventor.
noramlly i do not have troubles with .SLD files
just if you have passion for it would you like to check the files or send them to me m_gernot (ät) gmx (pot) at
i mean creating a basic motor model is really easy but your look really nice
greets
s28400   100 W
Post by s28400 » Jun 09 2016 5:27pm
Sure thing, here are the models in stl and step format:
notger   100 W
Post by notger » Jun 09 2016 11:05pm
works perfect, thanks
nowind   100 W
Post by nowind » Jun 10 2016 12:00am
thanks
notger
The Alien have TWO Pitchcircles, the larger one is 44mm.
Jenso
notger   100 W
Post by notger » Jun 10 2016 12:09am
nowind wrote: The Alien have TWO Pitchcircles, the larger one is 44mm.
Jenso
Hi, so i guess i can count with a standard of 44mm pitch with most motors and some do have 30mm (too, or weired standards)
I anyway will use some of the "usual" motors, so ill make my mount with 44mm, and rather look for fitting motors than making individual mounts.
thanks guys
