Need Help!! 6354 Brushless Motor Stuttering
papertriping   10 W
Post by papertriping » Jun 25 2016 7:57am
Hey Everybody!
I have a Turnigy SK3 6354 Motor connected to a Turnigy 150A ESC and 6s lipo.
I used the setups with/as friction drive on my penny board back in 2014. It worked like a charm- did a lot of powered riding and everything was great for about 4 months since I got all the components.
One fine day- while riding the motor made some beeping noises and then started to stutter. I was so upset - and thought i had broken the motor by using it on a friction drive. Not knowing how to fix- i put it away.
I've missed riding an electric skateboard and finally want to try and fix it- or at least understand whats wrong with it- so i can try and fix or replace the faulty component.
Here's what happens
https://www.youtube.com/watch?v=irJH-Uc7wwE
Any senior members here know what could be wrong here? please help
thanks in advance!
|Pen E-Board| Smallest E-board ever| http://endless-sphere.com/forums/viewto ... 35&t=63223
beto_pty   1 kW
Re: Need Help!! 6354 Brushless Motor Stuttering
Post by beto_pty » Jun 25 2016 11:59am
Havent ridden in ages..
Might be the magnets in the motor.. it would rock if you had a second esc and motor to verify if the problem is the esc or motor..
If i had to guess (which i do..) Sound like you smacked (if there is a dent on the motor) or spun it out (if there i no dent) the magnet out of alignment.. If so the motor is probably busted. Try opening the case, and verifying if the magnets look orderly.. if one looks weird there ares pecialty glues you can paste the magnets with never actually done it myself as the fixed motor will at some point cog again and spit you off, (so i just cry a bit and throw them out) however i belive this video might have some clues....https://www.youtube.com/watch?v=b1mHfdbLaY8
if it were the esc .. change the timing from high to normal but i seriously doubt it is the esc..
good luck
Do or Do not. There is no try
PATY/neta http://endless-sphere.com/forums/viewto ... 35&t=65384
MIni-motor Build http://endless-sphere.com/forums/viewto ... 35&t=56839
Destroyer http://endless-sphere.com/forums/viewto ... 35&t=58504
Adrianas Board http://endless-sphere.com/forums/viewto ... 35&t=61171
Gargoyle http://endless-sphere.com/forums/viewto ... 35&t=61569
Velociraptor: 6s 10.4ah, Ezrun150, 9.8 mm abec11s, Quanum, 5060NTM, 16/48 hdt5, Piggyback Charge
papertriping   10 W
Post by papertriping » Jun 26 2016 5:27am
Hey Thanks Beto_pty.
I've opened up my motor- and i'm looking around for what the problem could be....
Will post my findings soon
