Metos's project - VANGUARD | VESC | 6390 3.5KW 170KV | 12S
metos   1 mW
Post by metos » Jul 13 2016 6:34am
Hello
I'm new to esk8 community. I discovered esk8 with the Casey Neistat videos on youtube.
And as I'm a maker more than a buyer, I started to search how to build one
I'm french, living in Paris France and I joined the community e-sk8.fr with their great forum.
I'm posting my project here to share it with non french speaking people.
getting advices and giving inspiration and feedback.
I choose the Loaded Vanguard to match the boosted board design.
I first wanted to go for a dual rear motos/vesc but this is to much money for a first try.
So I get a massive 3.5Kw 6390 from Alien.
http://alienpowersystem.com/shop/brushl ... 0kv-3500w/
Here is my build spec
- Deck : Loaded Vanguard flex 3
- wheels : Kegel Orangatang 80A
- Trucks : Caliber 2 50° black
- ESC : VESC esk8.de
- Motor : Alien 6390 3.5Kw 170Kv
- Batteries : 12S 5Ah (4x 3S1P 5000mAh) Lipo
- Mount : Home made + alien caliber adaptors
- Gear ratio : 36/14
- switch : antisparks esk8.de
- charger : 2x IMAX B6
WeeChumlee   1 kW
Re: Metos's project - [VANGUARD | VESC | single 6390 3.5KW 1
Post by WeeChumlee » Jul 15 2016 4:58am
Hi metos,
Nice board, look forward to seeing the end result.
Personally I think you made a very wise choice in motors. That is a huge and heavy motor, but still far less than two 63mm motors.
I cannot see you needing any more power than that, my single 6374 170KV does me just fine on 8S so your 6390 170KV on 12S will be amazing.
The only consideration I have is the power, while accelerating uphill, to drive that thing may be a bit much for the VESC - I know mine strained (heat) on 8S, maybe on 12S it will be fine. I hope so.
Have fun.
torqueboards   100 MW
Post by torqueboards » Jul 15 2016 3:43pm
Nice.. huge motor. Very big.
DIYElectricSkateboard.com Electric Skateboard Kits
metos   1 mW
Post by metos » Jul 15 2016 6:33pm
Here is the Beast :D
metos   1 mW
Re: Metos's project - VANGUARD | VESC | 6390 3.5KW 170KV | 1
Post by metos » Jul 17 2016 5:24pm
Quick Test on video
https://youtu.be/4bWrTuCabpA
(youtube tag to include video seems to not working... ?!)
okp   100 kW
Post by okp » Jul 18 2016 12:47am
it does, just put the video ID into the brackets (not the full/short URL)
metos   1 mW
Post by metos » Jul 18 2016 2:52am
Ok thanks
metos   1 mW
Post by metos » Aug 17 2016 7:27am
I'm working on the enclosures, nothing to show yet :)
rootwalla   10 µW
10 µW
Post by rootwalla » Aug 20 2016 11:18am
Pretty sweet setup you got there. What range are you getting with this setup?
metos   1 mW
Post by metos » Aug 24 2016 8:14am
about 20Km
and top speed : 35Km
but i'm with a 36/14T gears ratio
i can switch to 36/15 to gain in to speed.
not tested yet.
ebooosted   1 mW
Post by ebooosted » Dec 09 2016 10:48pm
Did you finish your build?, I mean did you maka the enclosure?
metos   1 mW
Post by metos » Dec 11 2016 5:28am
Hello
I made enclosure for batteries but not yet for vesc and switch.
I dont have enough time to finish the build for now, but the board works well anyway.
Here is the current state
s28400   100 W
Post by s28400 » Dec 12 2016 7:15pm
What kind of current are you pushing to the motor? You may notice the board begins to feel sluggish after a few minutes of riding as the VESC will most likely overheat and start limiting the current to the motor in that enclosure. I would recommend installing an external heatsink that contacts some of the FETs or a vent for air flow. The only problem with the latter is that it won't do well with water. Looks like a fun build!
Cheers!
My Project Site: https://www.radicalcreation.com
Science may set limits to knowledge, but should not set limits to imagination.
metos   1 mW
Post by metos » Dec 15 2016 9:52am
I experienced this behaviour
I tried something like that
my final enclosure for the Vesc is not done, so I will include air flow opening to cool the Vesc, but that must not let dust and water going inside.
