Alibaba 50 dollars VESC worth it?
mrpj
Re: Alibaba 50 dollars VESC worth it?
Post by mrpj » Sep 09, 2016 5:01 am
Any updates?
Wonder if it is possible to order small quantities (1-2) by now?
AreaKruzer
Post by AreaKruzer » Sep 12, 2016 10:19 pm
any news on how the Alibaba VESC performs?
ralphy
100 µW
100 µW
Post by ralphy » Sep 22, 2016 5:39 pm
AreaKruzer wrote:any news on how the Alibaba VESC performs?
I wonder if hes alive?
Dauntless
Post by Dauntless » Sep 22, 2016 6:57 pm
Either the VESC blew up and got him or the seller found out he was ratting them out here and put out a hit.
- Arthur C. Clarke
ralphy
100 µW
100 µW
Post by ralphy » Sep 23, 2016 3:01 pm
I got a mp83mm motor and it lasted 2 days, blew up. It didn't take me though.
liveforphysics
Post by liveforphysics » Sep 24, 2016 12:00 am
ralphy wrote:I got a mp83mm motor and it lasted 2 days, blew up. It didn't take me though.
We're glad you're ok Ralphy!
Can you share a picture of your setup and the burned ESC so we can perhaps figure out what happened? I've got projects running this controller and I'm curious to see failure modes (which may or may not be related to mfg issues or swapped component choice or whatever).
Thanks!
ralphy
100 µW
100 µW
Post by ralphy » Sep 24, 2016 8:42 am
https://youtu.be/YfcNJ3yFgbg
liveforphysics wrote:
ralphy wrote:I got a mp83mm motor and https://youtu.be/YfcNJ3yFgbgit lasted 2 days, blew up. It didn't take me though.
Thanks!
Sure
Well the motor I'm pretty sure was defective since the beginning because it got really hot just riding slowly at 15 mph on a flat surface. The vesc had the old 2.16 firmware and I upgraded it to 2.18 via BLDC so I can read it's configuration and reduce the power output. It was way to sensitive powerful and fast.
This is a video I sent the manufacture of the failure. Hopefully the vesc didn't get damaged
mrpj
Post by mrpj » Sep 24, 2016 2:39 pm
Did you also buy your vesc from ali?
Which seller did you use?
ralphy
100 µW
100 µW
Post by ralphy » Sep 24, 2016 2:49 pm
mrpj wrote:Did you also buy your vesc from ali?
I bought it all together, motor vesc and control. I wouldnt like to specify the seller since the issue hasnt been resoved yet and my intention is to build a good project no give them bad publicity.
silviasol
Post by silviasol » Oct 07, 2016 4:52 pm
How much are their hub motors?
What speed does it go with 12s or what speed did you get and battery voltage?
Current project: 10s 20ah sensored goped hoverboard
https://endless-sphere.com/forums/viewto ... 35&t=62155
Ryuudan
Post by Ryuudan » Jan 30, 2017 8:08 am
Any news on the case? I'm about to buy new VESCs and would like to know if the issue got resolved before buying.
thank you.
