Alibaba 50 dollars VESC worth it?
Re: Alibaba 50 dollars VESC worth it?
Postby mrpj » Fri Sep 09, 2016 5:01 am
Any updates?
Wonder if it is possible to order small quantities (1-2) by now?
mrpj
Postby AreaKruzer » Mon Sep 12, 2016 10:19 pm
any news on how the Alibaba VESC performs?
AreaKruzer
Postby ralphy » Thu Sep 22, 2016 5:39 pm
AreaKruzer wrote:any news on how the Alibaba VESC performs?
I wonder if hes alive?
ralphy
100 µW
100 µW
Postby Dauntless » Thu Sep 22, 2016 6:57 pm
Either the VESC blew up and got him or the seller found out he was ratting them out here and put out a hit.
Any sufficiently advanced technology is INDISTINGUSHABLE FROM MAGIC!
- Arthur C. Clarke
Dauntless
Postby ralphy » Fri Sep 23, 2016 3:01 pm
I got a mp83mm motor and it lasted 2 days, blew up. It didn't take me though.
ralphy
100 µW
100 µW
Postby liveforphysics » Sat Sep 24, 2016 12:00 am
ralphy wrote:I got a mp83mm motor and it lasted 2 days, blew up. It didn't take me though.
We're glad you're ok Ralphy!
Can you share a picture of your setup and the burned ESC so we can perhaps figure out what happened? I've got projects running this controller and I'm curious to see failure modes (which may or may not be related to mfg issues or swapped component choice or whatever).
Thanks!
Ebikes.ca
My bicycle completes the standing quarter mile in 11.502seconds at 110.56mph.
Giving my time to the electric revolution is done with pleasure. It is no longer fashionable to spit carcinogenic combustion by products in peoples faces as a part of sating daily transport.
Every post is in honor to the free idea exchange that Justin le preserved to grow with an amazingly high quality content in what is the living bleeding edge of LEV development.
liveforphysics
Postby ralphy » Sat Sep 24, 2016 8:42 am
https://youtu.be/YfcNJ3yFgbg
liveforphysics wrote:
ralphy wrote:I got a mp83mm motor and https://youtu.be/YfcNJ3yFgbgit lasted 2 days, blew up. It didn't take me though.
Thanks!
Sure
Well the motor I'm pretty sure was defective since the beginning because it got really hot just riding slowly at 15 mph on a flat surface. The vesc had the old 2.16 firmware and I upgraded it to 2.18 via BLDC so I can read it's configuration and reduce the power output. It was way to sensitive powerful and fast.
This is a video I sent the manufacture of the failure. Hopefully the vesc didn't get damaged
ralphy
100 µW
100 µW
Postby mrpj » Sat Sep 24, 2016 2:39 pm
Did you also buy your vesc from ali?
Which seller did you use?
mrpj
Postby ralphy » Sat Sep 24, 2016 2:49 pm
mrpj wrote:Did you also buy your vesc from ali?
I bought it all together, motor vesc and control. I wouldnt like to specify the seller since the issue hasnt been resoved yet and my intention is to build a good project no give them bad publicity.
ralphy
100 µW
100 µW
Postby silviasol » Fri Oct 07, 2016 4:52 pm
How much are their hub motors?
What speed does it go with 12s or what speed did you get and battery voltage?
Last edited by silviasol on Fri Oct 07, 2016 4:55 pm, edited 1 time in total. View post history.
Current project: 10s 20ah sensored goped hoverboard
viewtopic.php?f=35&t=62155
silviasol
Postby Ryuudan » Mon Jan 30, 2017 8:08 am
Any news on the case? I'm about to buy new VESCs and would like to know if the issue got resolved before buying.
thank you.
Ryuudan
Previous
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: trolli and 4 guests
