Hi there, this is actually my first post so let me know if I'm following the proper etiquette for this forum.
I have all my parts in hand but I have a few concerns about what I've actually ordered, the overall assembly and mounts.
Here is my parts list:
2 x 4200maH LiFePo4 Batteries (https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14070)
1 x 2750W / 193KV Brushless Outrunner DC Motor (https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18129)
1 x Speed Controller (https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10944)
1 x UBEC (Universal battery eliminator circuit (https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6320)
1 x Austin David's Modified Wii-mote (http://austindavid.com/jm3/index.php/hardware/3-wiiceiver)
Here are some of the concerns I have regarding my configuration:
(1) The LiFe batteries are proving to be a pain in the ass, not much support for them and I'm concerned on finding a good charger for them. (I'd eventually like to make a charging port on the board)
(2) The total voltage on the batteries is 26.4 V, will this affect my top speed? I was told I should be supplying the maximum voltage to the motor (44V) Will the ESC take care of this?
(192 RPM/V) * (26.4 V) * (pi * 8e-5 m) * (14/36 gearing ratio) * (60 min/1hr) = 30 km/h ( I could probably fix with gearing ratios but I don't want to make my own gears)
(192 RPM/V) * (44 V) * (pi * 8e-5 m) * (14/36 gearing ratio) * (60 min/1hr) = 50 km/h
(assuming no losses so probably * 0.75)
If the ESC doesn't handle this, is my only real option to add more batteries in series? Also, since LiFe have a different nominal voltage compared to Lipo, I don't think I can actually reach 44V with 4s packs.
(3) I need a proper motor mount. I've done some sketches and I think I could cnc one to be welded onto the truck, but a screwable mount would be preferable for prototyping. (Perhaps a 3d printable model? If someone has one)
(4) Lastly, are all the parts appropriate?
Is the motor overkill? Is there a smaller motor that could supply me with 35km/h speeds in practice (a 50mm if possible)
Should I switch to LiPo or can I solve these issues with Life?
Is the ESC a good match? The BEC?
Sorry if this is a lot of questions, I just am trying to finalize the prototype and could use the guidance of someone with experience.
Any help would be appreciated! Thanks for input!
