Thermoforming Kydex
stealth71   10 W
Thermoforming Kydex
Post by stealth71 » Sep 04 2016 10:10am
I recently made a battery enclosure for my eskate and documented it along the way. I used 0.080 inch Kydex sheet and heated it in the oven then pressed it with a homemade press. Learned a lot and figured I would share for anyone that wants to try something similar. What kind of things have you built by thermoforming?
spinningmagnets   100 GW
Re: Thermoforming Kydex
Post by spinningmagnets » Sep 04 2016 11:07am
Thanks for posting this. I'm sure this will prove to be very useful for a lot of builders here.
torqueboards   100 MW
Post by torqueboards » Sep 04 2016 11:53am
Nice looks good. Kydex is definitely much easier to thermoform than ABS pretty durable too considering a lot of knives and gun holsters kydex is used.
In your oven though, I did that before. Bad idea.. I had ABS Pizza for days.. took 3+ hrs of cleaning to get rid of it.
DIYElectricSkateboard.com Electric Skateboard Kits
tomjasz   10 GW
Post by tomjasz » Sep 04 2016 1:51pm
Thanks for the ideas! I just found a dozen or more vacuum press builds too. Off I go! I love my Kydex holsters and now I can have Kydex battery cases! THANKS!
drew12345   10 kW
Post by drew12345 » Sep 04 2016 9:27pm
Cool, thanks for sharing.
stealth71   10 W
Post by stealth71 » Sep 05 2016 10:25am
torqueboards wrote:Nice looks good. Kydex is definitely much easier to thermoform than ABS pretty durable too considering a lot of knives and gun holsters kydex is used.
I put it on a piece of parchment paper on a cookie sheet. Never got hot enough to turn to goo. I think Kydex has different properties than ABS as well.
stealth71   10 W
Post by stealth71 » Sep 05 2016 10:30am
tomjasz wrote:Thanks for the ideas! I just found a dozen or more vacuum press builds too. Off I go! I love my Kydex holsters and now I can have Kydex battery cases! THANKS!
I though about vacuum forming, but wanted the box tightly formed to the shape of the deck. In the future I might try it after making a mold of the deck so I can use a smaller vacuum table. Building something deck size would be more difficult. This worked out pretty well and I think the end result was well worth the effort.
I will be making another one for the ESC soon and will post more videos. Editing the mounting video now and should be up soon.
SteveS   100 mW
Post by SteveS » Sep 07 2016 12:11pm
Am I right in thinking this stuff is more flexible than ABS? If so, it seems like a great option for enclosures for flexible decks!
MrDude_1   100 kW
Post by MrDude_1 » Sep 07 2016 1:43pm
nicely done sir!
Having worked with Kydex before, I can say you did an awesome job. A piece that large and flat is very hard to do, and you managed to keep the texture even.
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
stealth71   10 W
Post by stealth71 » Sep 07 2016 5:19pm
MrDude_1 wrote:nicely done sir!
Thank you.
stealth71   10 W
Post by stealth71 » Sep 07 2016 5:22pm
Here is the latest video Part 3 Mounting:
And Part 1 making the Buck:
