Please advice on electric system
AreaKruzer
Hi all,
I am hoping to build a DIY E-skateboard that can push me, that weighs 230 to 235lbs. I'm using 8s lipo batteries.
I need help with the motor choices
1) 1 x 6374 270kV motor - 2900W
2) 1 x 6364 200kv motor - 3150W
3) 2 x 6355 270kV motor - 2050W per motor
4) 2 x 6364 200kV motor - 3150W per motor (i'm afraid this will have trouble mounting at the dual rear configuration)
Gearing wise i am looking at 16/36T.
I will not be riding much inclines but even if i do, it will be short inclines of 20 to 25% at the max. So i need you guys to shed some light on this and also give me some tips.
I want to know which of the 4 choices above will be sufficient. I dont need it to be overpowered. Just a good enough torque to move myself with acceptable torque.
Thanks in advance.
Hi
I weigh about 200lbs and ride a 8S setup with a single 6374 170KV motor.
Does all the hills in my area without a problem and is fast enough for me. (No speed demon at all though)
