So I recently bought the enertion motor mount with a bunch of other mechanical and electrical parts i bought following this tutorial:
http://www.instructables.com/id/Electric-Skateboard-v20/
I am having issues with the battery cables.... every time i plug anything i get a fireworks show... here is a link to the diagram i am using from an instructables tutorial
https://endless-sphere.com/forums/download/file.php?id=203380
Wiring the electronics is turning out to be seriously problematic as any time i try to plug anything in i get a fireworks show...
1. There is no mention of the T plug for charging anywhere in the tutorial... but it is in the diagram posted above... is this related to a SERIES ADAPTER... if so he does not mention a series adapter anywhere in the tutorial and is not answering questions in the comments for a couple of months now... how is someone supposed to hook up the t plug that bypasses the ESC for charging... is this even where he is saying to charge the batteries or is that what the balance adapter is for? ALSO HOW DO YOU EVEN CONNECT AN IMAX TO A T-PLUG CONNECTOR WOULD I BETTER OFF USING A DIFFERNT CONNECTOR THAT COMES WITH THE IMAX???
2. the guy that made the tutorial posted in the comments that "The diagram is wrong. The balanace ports are flipped." i think i get this... the balance ports need to be switched from their respective batteries... no big deal... but if i'm wrong on that please correct me...
3. also does not mention in the tutorial how to charge the batteries (through the balance port?? or the T plug that he gives no mention of on how to set up????) i've heard that youre supposed to cut one of the red wires on on the balance adapter that is connected to the negative battery... he does not say to do this in the tutorial...
4. he says to buy banana jacks in the materials list and theres no further mention of how to use them...
ive come to realize that wire connectors are serious business so this guy has a lot of nerve to just say to buy banana plugs then have T plugs being in the diagram without any mention of them in the tutorial... never mentioning using a series adapter or 10 guage wire to bypass the ESC for charging (which is part of my question because he never indicates where the thing shoul be charged and what the whole point of including a balance adapter on the setup even is)
Im a total newb with knowledge about the mechanical stuff but pretty much no knowledge or experience on electrical stuff except what components are needed.. the difference between 6s and 8s... series vs parallel... etc... I dont know much about connectors except that one can solder differnt ones onto wires... also...
Honestly... i feel like im never going to have an electric skateboard at this point... the creator of this tutorial has probably caused a couple of peoples houses to burn down... and is no longer responding to questions in the comments... he tauted that hed be selling this bluetooth smartphone reciever on his website and you go to the website and it wouldnt even be up for sale or would be sold out for years at a time... basically one problem after another and very unprofessional... im just hoping to get through this and not take the loss on $400 of parts
ALSO HERES A LINK TO A DETAILED YOUTUBE VIDEO OF THE ELECTRONICS SETUP... THIS HELPED A LOT BUT I THINK HES BEIN A BIT OF A SNOB ABOUT THE BATTERY CURCUIT... IS THERE ANY WAY THAT THIS CAN BE SIMPLIFIED?
https://www.youtube.com/watch?v=Nkj5jVmRqUs
