Edit: after posting this, I went back and watched the entire video...he didn't figure out yet how to dial the system in to actually weld aluminum, but...this is still a great idea, and when I find a video or website with the info needed to complete the aluminum welding job, I'll post it in this threa.
Using a salvaged microwave oven transformer (MOT) to create a desktop welder for small aluminum welding jobs.
https://www.youtube.com/watch?v=fQXBNkaB1tU
[youtube]fQXBNkaB1tU[/youtube]
Here's an article on hooking up two MOTs in series to make a welder, and even though he's welding steel, there is aluminum welding rod available. Of course, I still need to find out what thickness of aluminum rod, and what volts and amps need to be used to weld aluminum. You can vary the number of wraps on the secondary coil of the DIY MOT in prder to lower the voltage, and by using fewer wraps, you can fit thicker wire to raise the amps.
One of the reasons store-bought welders are as expensive as they are is that they are adjustable. If you are making a welder to do only one job, you only have to adjust the wraps of wire once.
http://mods-n-hacks.wonderhowto.com...sing-parts-from-old-microwave-part-2-0146590/
