Problem with connecting remote, esc and motor
Postby lemon » Sat Jan 28, 2017 9:03 am
Hi,
it's been a while, but I have all parts laying around and wanted to start building the thing (viewtopic.php?f=35&t=82548)
parts list:
ESC: FTV 120A Car ESC
Motor: noname 270kV brushless motor
remote: HK GT2E (not GT2B)
But I am running into some problems:
1.) esc cables are blue, orange and yellow - motors cables are red yellow & black
which should i connect? i cant find a manual for that esc.
more problems following, i am sure :(
Last edited by lemon on Sat Jan 28, 2017 9:13 am, edited 1 time in total. View post history.
lemon
Re: Problem with connecting remote, esc and motor
Postby psychotiller » Sat Jan 28, 2017 11:57 am
It doesn't matter if the motor/esc is unsensored. plug the wires together. If your motor spins backwards switch any two of the wires around and it will spin forward.
Last edited by psychotiller on Sat Jan 28, 2017 11:58 am, edited 1 time in total. View post history.
www.psychotiller.com
builds:
XT Wheels/Custom Hub & mount on Randal 180's/Drop Throughhttp://endless-sphere.com/forums/viewtopic.php?f=35&t=59259
6" Pneumatic Tire Drop Down/Drop Through http://endless-sphere.com/forums/viewtopic.php?f=35&t=60449
"Have you ever heard of Plato? Aristotle? Socrates? Morons!"-Vizzini
psychotiller
Postby lemon » Sat Jan 28, 2017 1:54 pm
they are colored different, how am i supposed to know which one ist right?
shall i try all possibilities? can i damage it by doing that?
lemon
Postby psychotiller » Sat Jan 28, 2017 2:17 pm
As I said, it doesn't matter.
Follow my directions and you will be fine. 8)
builds:
psychotiller
Postby lemon » Sun Jan 29, 2017 8:18 am
ok it works, but i control the motor by the steering wheel, how to fix that?
Last edited by lemon on Sun Jan 29, 2017 8:20 am, edited 1 time in total. View post history.
lemon
Postby xadmx » Sun Jan 29, 2017 9:48 am
lemon wrote:ok it works, but i control the motor by the steering wheel, how to fix that?
the gt2e sucks you can swap the connectors over inside the remote. but your best just to get a gt2b then you can use a 3d printed case.
xadmx
Postby lemon » Sun Jan 29, 2017 9:57 am
theres also a 3d model for the gt2e
and i bought the gt2e because the gt2b was not in stock (europe)
lemon
Postby psychotiller » Sun Jan 29, 2017 8:55 pm
You should be able to unplug your receiver wire from channel 2 in you receiver and put it in channel 1.
builds:
psychotiller
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 3 guests
