Velocifero Mad scooter upgrade
shinyballs   1 kW
Post by shinyballs » Oct 04 2017 6:45am
Delivered on a thick cardboard box weighing 120lbs, so scooter weighs approx 110lbs. 52 inches long. The frame, fork, swing arm and seat post are made of steel.
The battery frame housing has enough room for 200 18650 cells plus other things. I'll use either Samsung INR18650-35E or Panasonic NCR18650PF configured as 20s10p - which battery do you guys prefer?
Has anyone tried the 18650 nickel strips from nkon? will be ordering the cells from them.
Going to replace the rear rim with a hub motor of the same size and use a larger Sprocket.
Power target is 4 kW max continuous.
MTMad1600_Blue_3 - Copy.jpg (118.59 KiB) Viewed 2515 times
Sale section etiquette, pls be courteous to other members, if you know of a better deal or do not agree with the sale price, do not shove links to similar products being sold by someone else in another member's post.. it's just not nice. If you suspect a scam pls FLAG the thread for moderation and it will be checked out... i know this is a tough one to call but put yourself in the seller's shoes and imagine how you would like it.
http://endless-sphere.com/forums/viewto ... 31&t=25446
ElectricGod   100 MW
Re: Velocifero Mad scooter upgrade
Post by ElectricGod » Oct 28 2017 10:14pm
Don't bother with the hub motor. Seriously... DON"T use a hub motor. A hub is lots of unsprung weight in the back wheel and your scooter has suspension, so use it and you have a nice place to mount a motor in the frame. A far better option is getting an outrunner such as the C80100 which is rated for 6kw. I know what motor you have already and the C80100 is about 60% the size of that BOMA inrunner and good for 2-3X the wattage. It will easily fit in the same space as your factory motor. You wil lalso need to upgrade to 219 sprockets and chain.
You have a giant battery bay. You should easily get 30-40 miles range and top out at around 50mph with the right set up.
This is a Chinese scooter similar to yours that I upgraded. It runs at 82 volts and I've speed tested it at 60mph! On level ground it tops out at 50mph and out accelerates most cars.
https://endless-sphere.com/forums/viewt ... er+project
Since your deck isn't flat, this will be more of a pain to do, but you will want to seal up your deck to the battery bay to keep dirt and water out. Also, that will give you an extra inch or so of space for more batteries or whatever inside the battery bay. I'd probably make triangle pieces to fill in or level out those low spots and make a new deck that was flat.
shinyballs   1 kW
Post by shinyballs » Jan 21 2018 8:53pm
Existing sprocket on the rear has 70T. Does anyone know where I can find a >99T 8mm/T8F sprocket?
Lurzarac   1 µW
Post by Lurzarac » Jul 30 2018 9:33am
Can u update ur progress please?
Hi Im lurza..i posses mad velocifero 500w scooter..i am in looking to upgrade my escooter as well but need advice where to start.
