"Monster Board" High power 4X4 board with ATV tires
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Re: "Monster Board" High power 4X4 board with ATV tires
Post by recumpence » Oct 04 2018 12:23pm
Wheelbase does make a difference. Steering geometry players a bigger role in this type of vehicle, though.
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence   100 GW
Post by recumpence » Oct 06 2018 6:46pm
Grip tape installed. The arrow points to the nose of the board. Being symmetrical, knowing what end is the front is a good thing!
Also, I picked up an ATV jack at Walmart for $52. Perfect for board service.
Matt
Silenthunter   100 W
Post by Silenthunter » Oct 15 2018 10:46am
This is RAD! Matt, have you thought of making a similar design but in smaller size? A more portable eboard?
recumpence   100 GW
Post by recumpence » Oct 17 2018 10:46pm
A couple pictures. Though can see the powder coating color of the steel parts and you can see the amount of articulation.
kerim   10 mW
Post by kerim » Oct 19 2018 4:12am
Nice video!
https://youtu.be/sNSKmLGvU_0
Cannot wait to see more videos of that thing...
recumpence   100 GW
Post by recumpence » Oct 22 2018 10:22pm
https://youtu.be/oW0UVqTGKyQ
I've been riding the board for hours without any problems at all. I am getting quite good at riding it.
OBone   10 mW
Post by OBone » Oct 24 2018 1:19pm
That is a very, very good piece of work. Well done.
Taken it rock crawling yet? My next comment is based on extensive 4x4ing, and having no experience with mountain boards. But i think you are going to miss the solid axle shaft.
Rule of thumb is is good articulation lessens the need for diff lock. But because one then tend to go into the rougher stuff, once you do get hung up on an obstacle you need diff lock even more.
But that is on a vehicle you can't exactly pick up . Otherwise you might have to fabricate diff locks as well
Sent from my SM-G955F using Tapatalk
Mondays. What a silly way of spending 1/7 of your life
recumpence   100 GW
Post by recumpence » Oct 24 2018 2:13pm
Great observation. Differentials are absolutely needed for this board to steer. In fact, open differentials are the only way to go. It is possible that rock crawling could be adversely affected with the lack of lock. But, it's the only way to make a lean steer vehicles steer properly. I've been climbing up-and-down curbs both straight on and at an angle. I'll be posting a video of the results soon. It climbs really well.
Silenthunter   100 W
Post by Silenthunter » Oct 27 2018 1:38pm
Video please...I would like to see the beast climbing some big obstacles.
recumpence   100 GW
Post by recumpence » Oct 30 2018 7:01pm
I just did some testing. At a full charge on pavement, the board runs 20mph. It runs 18mph max speed off road through most of the charge. Any faster and I get a bit of speed wobbles. Let me tell you, 20mph is really moving off road on a skateboard.......
SlowCo   100 kW
Post by SlowCo » Oct 31 2018 6:16am
Maybe place a kart seat on the deck and use the balance of your arms and upper body to lean the board. That should give an interesting drive/ride so low down.
Make it easily detachable to switch between stand up board and low ground, off road "balance karting". 8)
(just thinking outside the box... :mrgreen: )
recumpence   100 GW
Post by recumpence » Oct 31 2018 5:09pm
Yup, my wife even asked me if I was going to do that.
I can tell you it is cool to kneel down on the board and ride it.
Sitting on the board tends to generate wobbles easily. But, I will see if I can tune the wobbles out somehow.
recumpence   100 GW
Post by recumpence » Oct 31 2018 6:09pm
macribs   1.21 GW
1.21 GW
Post by macribs » Nov 01 2018 5:43am
Did you post wrong link? I am certain I saw that video last week.
recumpence   100 GW
Post by recumpence » Nov 01 2018 6:38am
Not sure what happened to the new video. Looks like I need to re-upload it....
