"Monster Board" High power 4X4 board with ATV tires
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Re: "Monster Board" High power 4X4 board with ATV tires
Post by recumpence » Feb 14 2018 6:00pm
The upper control arm is adjusted by rotation to vary the pivot angle.
I am pointing to the arm here. The heim Joints are right hand thread at one end and left hand thread on the other. This allows length adjustment by simply spinning the arm without disconnecting either end of the arm. This makes adjustment super easy.
My wife and son will be out of town this weekend. So, I we'll be working on the board feverishly. I hope to have the trucks mounted (with steering dampers and related equipment) and the drive units installed. The board should look somewhat complete by this weekend.
This thing is freaking GARGANTUAN! I knew what the overall measurements would be. But, seeing it layed out with all components, it looks so huge!
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence   100 GW
Post by recumpence » Feb 14 2018 6:01pm
The angle in adjustable from roughly 30 degrees to 55 degrees.
rojitor   100 kW
Post by rojitor » Feb 14 2018 6:22pm
This project is starting to get shape. Looks amazing. Can't wait to see the final design
Rikobonito   100 W
Post by Rikobonito » Feb 15 2018 9:07pm
This is going really biiig !! Awesome build, good continuation :wink:
my little blog with e-sk8, e-Cruiser, e-pintail, e-MTBoard, e-Dirt Scooter and others builds
... I wish also an e-MTBike soon !! :v: Thanks DIY Power community :wink:
recumpence   100 GW
Post by recumpence » Feb 17 2018 6:53pm
I have begun building the trucks.
Here is the axle assembled with sprocket and hubs.
recumpence   100 GW
Post by recumpence » Feb 17 2018 6:57pm
Here is the main tube for the truck. The bearing fits into the end snugly. Flanged bearings are not easily available. So, in order to use a non flanged bearing, I must install a back stop. Here you can see the piece of aluminum tube I cut to install in the main tube as a bearing back shop.
recumpence   100 GW
Post by recumpence » Feb 17 2018 6:59pm
The back stop gets pressed in behind the bearing.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:01pm
The way I fixed the back stop inside the tube is by drilling holes around the tube and welding the back stop to the main tube through the holes.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:02pm
Here is the bearing and back stop pressed into the main tube.
recumpence   100 GW
Back stops welded in place with the TIG.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:06pm
Here is the center of the main tube. You can see I welded a curved doubler to strengthen the king pin junction. After welding the doubler, I milled a wide slot into center of the doubler to accept the king pin sleeve. This was done on both trucks.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:08pm
This is the kingpin sleeve. I machined both sleeves to allow them to recess deeply into the truck main tube.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:09pm
Here is the way the two parts will attach.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:10pm
Getting ready to weld.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:15pm
Welding done.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:16pm
Here it is assembled for the first time!
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:17pm
The suspension and truck assembly.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:18pm
Top down view.
recumpence   100 GW
Post by recumpence » Feb 17 2018 7:19pm
Turning radius and angle articulation.
The board will obviously have a wide deck on top of the frame. The deck will probably be 16, to 18 inches wide.
SlowCo   100 kW
Post by SlowCo » Feb 18 2018 11:02am
:lol:
That looks amazing! Great project again. Can't wait to see it finished and a riding video... :mrgreen:
recumpence   100 GW
Post by recumpence » Feb 18 2018 3:33pm
4 more hours of work netted some decent results.
Here is the competed deck (chassis). It is 17 inches wide. The sides have 10 degrees of kick-up. That is a touch over 3/4 inch concave in the middle of the deck.
The decking on top of the chassis will be 1/8 inch thick black G10 riveted down with 3/16 aluminum rivets. It should look very "Mad Max".
The 45 degree angle that the kick-up sides have at the corners was needed for tire clearance at max turning. Bear in mind, this thing is friggin HUGE. The 17 inch wide section of the deck is actually 26 inches long. So, PLENTY of room to stand even with tire clearance.
Some other bits were addressed today as well. But, nothing else worth showing.
Matt
recumpence   100 GW
Post by recumpence » Feb 18 2018 6:55pm
More pictures.
It is starting to look good......
recumpence   100 GW
Steering damper and drive unit placement.
recumpence   100 GW
Post by recumpence » Apr 20 2018 7:50am
I did some testing (just coasting) and found live axles will not work. Differentials are needed. So, I bought some generic differentials. Modifying the trucks to accept the differentials is the next step.
Matt
