motor wires interfere with reciever?
Hummina Shadeeba   1 MW
Post by Hummina Shadeeba » Jan 17 2018 12:03am
will the motor wires interfere with my receiver antenna beside it?
Hariboisawesome   1 µW
Re: motor wires interfere with reciever?
Post by Hariboisawesome » Jan 17 2018 1:21am
It shouldn’t. If you are having issues with interference you could do like I did, add a “antenna “ to the receiver and drill a small hole for it to go through. Channel a place on top of the deck for it and just put grip tape over.
Post by Hummina Shadeeba » Jan 17 2018 3:04am
aren't the antennae kind of specific or fragile? can you simply extend the wire with another soldered on wire?
I thought I heard somewhere motor wires could interfere..any second opinions?
Buk___   10 kW
Post by Buk___ » Jan 17 2018 4:00am
Hummina Shadeeba wrote:
Jan 17 2018 12:03am
What sort of radio receiver?
fechter   100 GW
Post by fechter » Jan 17 2018 1:48pm
It depends on the type of radio and the frequency. The BMW i3 electric car doesn't even have AM on the radio due to interference issues. At higher frequencies, like WiFi, it should be no problem.
Post by Hariboisawesome » Jan 17 2018 2:05pm
Jan 17 2018 3:04am
I simply sort of spliced(?) twist my “extension” on the existing antenna
