Electric Dirtsurfer / In-line board
Farmer John   1 µW
Post by Farmer John » Feb 03 2018 9:55pm
First of all I’m grateful to have found such a knowledgeable group of people to lead me through my first e-anything project.
I intend to build an electric Dirtsurfer. After seeing other e-Dirtsurfers and researching this site I have a plan, but I would appreciate input along the way.
I have just ordered a Mac geared hub motor kit from emev3.
https://em3ev.com/shop/upgrade-mac-kit- ... 1500w-max/
I will power it with a 48 volt battery run at up to 30 amps cont.
I want to install a FRONT 536HF 8T Mac motor in the REAR wheel of the Dirtsurfer. The frame is made out of aircraft grade aluminum. https://upload.wikimedia.org/wikipedia/ ... _GP_03.jpg
The swinging fork is in the front FYI.
I plan to use a Grin V3 torque arm. I’ll use a rear disk brake connected to a hand brake lever, where a 3 way switch and thumb throttle will be mounted. The kit comes with a 9 fet 3077, 30 amp controller, which matches the 30 amp battery.
What’s your opinions, concerns, etc.? I’m looking forward to the discussion.
Thanks,
Steve
Chalo   100 GW
Re: Electric Dirtsurfer
Post by Chalo » Feb 03 2018 11:35pm
I don't think you're likely to have any problems with the default controller programming, nor the MAC kit in this application. I'm guessing you'll have as close to a plug and play experience as any of us get.
Consider using a non-round, lockable grip on whatever stub of material you have for your brake lever and throttle. I think positive orientation control will be key to making precise inputs.
If I were you, I'd be spending more thought on stuff like full face helmets, mouth guards, knee and elbow pads, wrist guards, shin guards, and low deductible health insurance.
markz   100 GW
Post by markz » Feb 04 2018 12:15am
Chalo wrote:
Feb 03 2018 11:35pm
The OP could be Canadian which means free health care. But its always wise to have extra health coverage like Blue Cross or Greenshield for an extra $50/month 8)
I've never seen something like that Dirtsurfer before, looks cool.
Raisedeyebrows   1 kW
Post by Raisedeyebrows » Feb 04 2018 1:25am
Looks like a lot of fun, I'll ride most anything you stand on sideways and goes forward but............I think I'd be more enthused if it had Longboard bindings, ones I could eject from easier. I did a fair amount of Longboarding at speed in my younger days and some mountainboarding too, yeah as someone mentioned above crash protection is a good thing.
Yuba Mundo w/BBSHD
Specialized Hard Rock w/9c clone, statoraid, hubsink
Trek Fuel 90 w/BBSHD
Above all run on 14s4p 52v li-ion
Ecobike folder 36v
Currie Flyer scooter 24v on 24ah of SLA
Every trip made with electric bike is one less car trip, saves money, no toxic fumes, less noise, less impact on roads.
eCue   10 kW
Re: Electric Dirtsurfer / In-line board
Post by eCue » Feb 04 2018 1:19pm
Looks like a blast to ride although i could see myslf getting injured semi regularly with it. Mostly lumps :D
Solar charge station on wheels join the Revolution
Farmer John   1 µW
Post by Farmer John » Feb 11 2018 1:23pm
Thanks Chalo for your thoughtful comments. A non-round mount is a great idea!
Could you expand on positive orientation?
And thanks to everyone for all the health concerns.
Farmer John   1 µW
E-Dirtsurfer / In-line Board
Post by Farmer John » Feb 11 2018 2:51pm
Chalo   100 GW
Post by Chalo » Feb 11 2018 5:04pm
Farmer John wrote:
Feb 11 2018 1:23pm
The Ergon grip or one of its many cheaper clones is what I was thinking of.
If you hold this in one hand, there's no way to be in error about what rotational position it's in, or the relationship between the grip and the throttle. With a round grip, simply pressing the throttle lever will tend to rotate the grip somewhat, making the throttle position less precise and identifiable. With an Ergon grip, it might move when you work the throttle, but you'll immediately feel it and be able to re-orient.
The same would tend to apply to a hexagonal grip or other distinctly not-round shape, as long as the grip locks positively to the stub of handlebar.
Farmer John   1 µW
Post by Farmer John » Feb 11 2018 9:32pm
Now I get it! Thanks Chalo.
I put the motor, brake, torque arm
and tire on the frame today.
When I get back from a trip I will put the
handle stub together.
