10s3p ESkate Battery Build Overview Video
Lash   100 W
Post by Lash » Apr 15 2018 2:27am
Hey, I thought i'd post this quick overview video of a battery I just finished for a customer.
In doing some research, there were people making batteries in all sorts of different ways. I chose this layout for better current share, faster build time and having the terminals at the same point as each other.
This layout I believe will perform better under skateboard flex conditions, and will not put any pressure on welds.
Check it out and let me know you comments / improvement ideas for my next ones and other builders.
For Aussies looking for custom electric skateboard batteries, just reach out and I can build and ship them to you.
Cheers.
Lash   100 W
Re: 10s3p ESkate Battery Build Overview Video
Post by Lash » May 15 2018 10:16pm
Sorry for late reply,The length and width were pretty much the dimensions of the cells. The customer had plenty of room in his enclosure for it, so basically 6 cells wide is ~ 120mm and 5 long is about 325-350mm.
height was about 22mm with a thin bit of foam underneath.
Cheers!
