GOPED ESR750 Battery Question
pattyballs   10 µW
10 µW
Post by pattyballs » Apr 18 2018 11:23am
Hello,
I have been browsing the forum recently after aqcuiring a Goped ESR750. It is currently 100% stock when it comes to the electronics and i would like to change that. I have view multiple "builds" and setups here but most are several years old at this point. I wanted to see what people are currently running in ESR's and find the best "User Friendly" setup to install. I have very little experience with electronics and would like to learn a little but find a very easy to use, build and maintain. Thank you in advance!
pattyballs   10 µW
10 µW
Re: GOPED ESR750 Battery Question
Post by pattyballs » Apr 18 2018 11:42am
I am curious if these batteries would be a good fit? Maybe get 4 of the 24v 10Ah? Thoughts?
https://www.uumotor.com/webstore/access ... on-battery
fechter   100 GW
Post by fechter » Apr 18 2018 2:35pm
That battery is a little weak for the ESR750. Ad states 15A continuous. You should look for something that can do 50A.
By replacing the lead bricks with lithium batteries, you could probably triple the range and reduce the weight quite a bit.
What are the dimensions of the battery compartment? Or measure the stock batteries.
pattyballs   10 µW
10 µW
Post by pattyballs » Apr 18 2018 2:42pm
Hey,
Thanks for the response! I have 4 SLA batteries currently. They are 5.95 L X 2.56 W X 3.7 H. I do have the deck spacer too which gives me some extra room to work with. What 50AH batteries are a more or less "Plug and Play" option?
pattyballs   10 µW
10 µW
Post by pattyballs » Apr 18 2018 3:36pm
Is there anyone that can work with me in making some custom 18650 Packs with the needed monitors and PCM/BMS?
Silenthunter   100 W
Post by Silenthunter » Apr 18 2018 11:33pm
check my youtube channel: portable electric vehicles. I did conversion of Goped esr 750H to brushless 6374 with 170kv and 10S li-ion 18650 plus the focbox. 25 mph geared and 16 miles in range with 22 amp pack.
Silenthunter   100 W
I also posted it for sale in order to fund further project.
fechter   100 GW
Post by fechter » Apr 19 2018 8:48am
A custom 18650 pack would be fairly easy for someone with the right tools.
I think you want your pack to be able to supply 50A maximum current, not 50Ahr capacity (two different things).
Silenthunter   100 W
Post by Silenthunter » Apr 19 2018 10:03pm
My packs delivers 150 amps continues! 10S10P with 30Q cells
pattyballs   10 µW
10 µW
Post by pattyballs » May 15 2018 2:16pm
Does anyone know of a quality battery builder? I have been doing a lot of research and think i would like to have some custom packs made to be plug and play.
Silenthunter   100 W
Post by Silenthunter » Jun 05 2018 10:00pm
I can build you one pack for goped.
