Hello there,
after reading many threads on this forum I finally managed to create an account to present my EV-journey. To make it less boring I added as many pictures as I could find
It all startet March 2016 when I bought my first electric scooter. It is called Mach1 1600W. I ordered one with offroad tires and went on trials in the woods all around our small village.
- IMG_7082.JPG (168.38 KiB) Viewed 3867 times
It was quite fun but the heavy batteries and high weight paired with only 1600w just wasn't enough after some time.
But I tasted blood of EVs.
Two months later I built my own scooter. It was a Hudora kick scooter with longer base and an Alien Power 6374 90kv, APS 120A ESC and 11s 4Ah Lipos. I had no plan about the perfect kv and voltage and stuff like that. I soon changed the motor for a 170kv and larger gearing. After much time and effort this thing went 50km/h (30mp/h) with a very good acceleration.
- IMG_9517.JPG (173.96 KiB) Viewed 3867 times
- IMG_9519.JPG (100.6 KiB) Viewed 3867 times
- IMG_9521.JPG (139.43 KiB) Viewed 3867 times
During summer in 2017 I made plans for a bigger and stronger scooter.
My shopping list that time:
Stunt Scooter as base (used Razor Phase Two on eBay)
APS 80100 130kv brushless motor
APS 200A 16s ESC
5000mAh 4s LiPo x4 = 16s
Aluminium profil to lengthen the deck and make room for the batteries
Wheel, Rim, disc brake, sprocket and chain from an electric scooter website
(wheel diameter 270mm, Gearing 14t to 63t)
Alumnium from eBay for custom parts and mounts.
- IMG_1061.JPG (52.07 KiB) Viewed 3867 times
- IMG_1062.JPG (101.98 KiB) Viewed 3867 times
- IMG_1105.JPG (135.42 KiB) Viewed 3867 times
- IMG_1114.JPG (87.48 KiB) Viewed 3867 times
- IMG_1115.JPG (92.2 KiB) Viewed 3867 times
- IMG_1116.JPG (95.96 KiB) Viewed 3867 times
Then the fun part began: putting it all together, fiddeling with electronics and space. You name it.
- IMG_1265.JPG (116.43 KiB) Viewed 3867 times
- IMG_1267.JPG (113.87 KiB) Viewed 3867 times
- IMG_1268.JPG (111.7 KiB) Viewed 3867 times
Installed an Arduino Mini to smooth out the throttle
- IMG_1336.JPG (124.8 KiB) Viewed 3867 times
The final state from 2017 with a top speed of just over 80kmh (or 50mph)
- IMG_1365.JPG (168.55 KiB) Viewed 3867 times
Here are two videos I also took in that time:
A fast pass:
