10kW stand-up scooter with air suspension
alex_2d   10 W
Re: 8kW stand-up scooter with air suspension
Post by alex_2d » Mar 03 2019 5:58am
alex_2d   10 W
Post by alex_2d » Mar 07 2019 4:35pm
Long video with testing of the cooling system.
fechter   100 GW
Post by fechter » Mar 11 2019 8:02am
The suspension seems to work amazingly well. Some of those roads are even worse than the ones around here.
alex_2d   10 W
Post by alex_2d » Mar 14 2019 2:00am
fechter wrote:
Mar 11 2019 8:02am
Tnx! The suspension really works perfectly!
Here are some more beautiful views and bad asphalt.
SlowCo   1 MW
Post by SlowCo » Mar 14 2019 4:41am
Great location to ride! Nice scenery and video :thumb:
izeman   100 GW
Post by izeman » Mar 14 2019 4:52am
fechter wrote:
Mar 11 2019 8:02am
After seeing those "streets" i will never complain about our's here. ;)
alex_2d   10 W
Post by alex_2d » Mar 14 2019 7:13am
alex_2d   10 W
Post by alex_2d » Mar 15 2019 1:04pm
Made changes to the controller settings. Finally got to make the most of it!
11.4 kW - 199.1A phase!
alex_2d   10 W
Re: 10kW stand-up scooter with air suspension
Post by alex_2d » Mar 16 2019 1:22pm
Today made another attempt to climb the mountain, hiking trail, and again failed :)
I do not understand what point he tore off a fitting cooling with the axis of the engine...
Without cooling, there was no point in continuing the ascent. And the oil began to fill the brake disc.
But it was fun to go down :) Had to make a few stops to dry the brake disc from the oil... But in general, regenerative brake was good, with a strong pull of the trigger, the rear wheel went into a skid.
At around 07:05 an exciting moment. I didn't notice the protruding part of the rock.
Here are the consequences:
LeftieBiker   10 kW
Post by LeftieBiker » Mar 16 2019 2:40pm
Maybe a stainless steel bash-guard?
alex_2d   10 W
Post by alex_2d » Mar 16 2019 3:53pm
LeftieBiker wrote:
Mar 16 2019 2:40pm
I plan to make a shield out of titanium =)
Short section of descent, with a better road:
alex_2d   10 W
Post by alex_2d » Mar 23 2019 1:05pm
Not sure if anyone's interested, but here's a video of the front suspension working:
LeftieBiker   10 kW
Post by LeftieBiker » Mar 23 2019 1:11pm
Loos like the damping and spring rates are dialed in, too.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Mar 23 2019 3:45pm
No need for any off-roading in your neck of the woods! :P
"Will you shut (TF) up, man?"
QANON is a sick cult: https://www.rollingstone.com/culture/cu ... e-1064076/
SlowCo   1 MW
Post by SlowCo » Mar 23 2019 5:45pm
Great video again!
Time to build a two wheel drive by installing a front hub motor :wink:
Your type of front forks with suspension would lend themselves perfectly for that!
Okami   10 W
Post by Okami » Mar 23 2019 5:49pm
Just wanted to drop a reply here.. im in pure amazement by all the photos and videos + text description included here..
Though this really set me in my place and now im thinking im really at the very beginning of electric vehicle building, when seeing a project such as this.. indeed, amazing!
alex_2d   10 W
Post by alex_2d » Mar 23 2019 6:42pm
Once again rewound the engine:-D Now the speed at idle - 97 km\h.
Here's a video from the first races:
SlowCo   1 MW
Post by SlowCo » Mar 23 2019 7:18pm
:shock:
Please stay alive and well...
j bjork   10 kW
Post by j bjork » Mar 24 2019 8:34am
Just amazing :D
I guess you mean that you were a lawyer, but now you are a cnc operator?
I can´t imagine the costs for machines and material just for hobby use..
John in CR   100 GW
Post by John in CR » Mar 24 2019 6:07pm
Great vehicle, but don't you think it's time to put that build expertise into something with larger diameter wheels more suitable to your riding conditions with far more comfort and safety?
tracer11lb   1 mW
Post by tracer11lb » Mar 28 2019 10:46am
What are the spec of the rear tire and motor?
alex_2d   10 W
Post by alex_2d » Mar 31 2019 12:43am
j bjork wrote:
Mar 24 2019 8:34am
Just amazing :D
Yes you are right, the last few years I am engaged in CNC.
I have my own workshop with several CNC machines, but the main direction is woodworking.
Scooter is really a hobby. Yes, materials and components are very expensive, but the main cost of the project is CNC processing, which costs me at cost.
John in CR wrote:
Mar 24 2019 6:07pm
In my opinion, my stand-up scooter is perfect for my driving conditions. Easier, faster and more maneuverable means of transportation, I have not yet come up. I've ridden a lot on a petrol scooter. I have a car. But only a stand-up scooter gives me real freedom of movement.
But you're right, the front wheel is not enough. I ordered new front tires 13x5.0-6. They are more at 2.5" in diameter. I'll make a replacement soon.
tracer11lb wrote:
Mar 28 2019 10:46am
Rear tyre from go-kart - 6,0\11-5
The diameter of the stator is 105 mm, the width of the stator is 60 mm.
The number of teeth of the stator - 27
The number of magnets - 30
Winding section - 2.56 mm2
Number of turns - 5
Number of revolutions per volt ~ 19.1
Power is limited by the controller - 11,4kW
tracer11lb   1 mW
Post by tracer11lb » Mar 31 2019 8:19am
alex_2d wrote:
Mar 31 2019 12:43am
Number of turns - 5
Thanks for the info. That is some amazing work. I want to build my own also and this inspired me alot. I am trying to buy parts one at a time and then tackle the frame when I get most of the parts needed to assemble it. Did you buy that motor if so, do you have a link? or did you machine the motor and built it from scratch also?
SlowCo   1 MW
Post by SlowCo » Mar 31 2019 11:46am
alex_2d wrote:
Mar 31 2019 12:43am
Doesn't the wide "flat" kart tire ride strange when trying to corner? Then you must feel an "edge" when leaning over?
alex_2d   10 W
Post by alex_2d » Mar 31 2019 9:14pm
tracer11lb wrote:
Mar 31 2019 8:19am
Yep :)
SlowCo wrote:
Mar 31 2019 11:46am
I had concerns about that.
The first 100 km, the tire was very hard and the edge was felt very strongly, causing discomfort when driving.
But then, either the tire got softer or I got used to it. At the moment I don't feel any minuses from the wide "flat" kart tire.
