New Dual Motor 10S VESC Build
PracticalProjects   10 W
Post by PracticalProjects » Jan 08 2019 2:47pm
Hello All,
Quite a while ago now I made an electric skateboard. If you're interested in that one here is a link to the intructable I made on it a while ago https://www.instructables.com/id/DIY-El ... teboard-1/ Since then the diy electric skateboard industry has moved on a lot with many companies now offering a variety of components for every build.
I intended on a dual motor setup but once again intended to stick to the idea of it being as diy as possible. However after some research I found several motor mounts and a full dual truck set up from diyeboard.com. I have to say I think it is almost impossible to actually make it cheaper unless you had access to a cnc machine. So this is what I went forward with.
Here is the parts I used for the build,
Drive System
DiyEboard/Flipsky Dual Drive Motor Kit
www.banggood.com/custlink/GKDvDkTtND
​Battery
DiyEboard 10s2p Battery Pack
goo.gl/5ofnfX
ESC
Flipsky Dual VESC
www.banggood.com/custlink/mvDDmU7V4u
Flipsky AntiSpark Switch
www.banggood.com/custlink/vK333quPeo
Remote Control
Alien Power System 2.4 Ghz
goo.gl/3RTK5W
I designed the enclosure on NX11 which was then SLS manufactured in nylon.
I used some m4 inserts which provide a secure and reusable connection to the board
I then assembled the rest of the board
And there it is, I made a quick video of the build with some initial testing if you're interested
More in depth review to follow, if you have any questions or feedback then please do leave a comment :)
rlynd3   1 mW
Re: New Dual Motor 10S VESC Build
Post by rlynd3 » Jan 13 2019 12:07pm
Looks great!
How is the power / speed with those banggood motors? That is a good price.
Where did you get the enclosure manufactured?
Cheers.
Post by PracticalProjects » Jan 14 2019 5:23pm
rlynd3 wrote:
Jan 13 2019 12:07pm
Looks great!
Cheers.
Hi,
Thanks very much for your comment!
I haven't ridden the board an awful lot yet (maybe around 8 cycles of the battery) but they seem to have plenty of power and speed at the moment. I weigh around 14st if that helps. It's definitely quick enough but haven't had chance to actually measure the speed yet but most people say they get around 25mph from similar set-ups.
The enclosure I was fortunately able to get manufactured at my university but there are a few companies where you will be able to get one printed.
rlynd3   1 mW
Post by rlynd3 » Jan 15 2019 11:27pm
Thank you for the information. I do miss havening access to University lab/shop equipment. Maybe now is a good time to go back for my masters... ;)
Cheers.
