Farfles Electric Ultralight.
Things that fly
Farfle   1 MW
Post by Farfle » Jun 21 2017 11:48pm
Heya all!! Started this project around the beginning of the year, and have made enough progress to post it up on the forum.
Heres some stats:
Airframe: Belite Ultracub
Motor: salvage Zero 75-5 IPM
Battery: Farasis 29AH 28S4P pack
Controller salvage sevcon Gen4 Size 4
Bms: None
Charger: Meanwell RSP2000 x2
This guy will be called Mk.5!
Test Review Revise Repeat
Farfle   1 MW
Re: Farfles Electric Ultralight.
Post by Farfle » Jun 22 2017 12:21am
Farfle   1 MW
Post by Farfle » Jun 22 2017 12:23am
Farfle   1 MW
Post by Farfle » Jun 22 2017 12:26am
Farfle   1 MW
Post by Farfle » Jun 22 2017 12:29am
liveforphysics   100 GW
Post by liveforphysics » Jun 22 2017 12:32am
So excited to fly in it!!!
Farfle   1 MW
Post by Farfle » Jun 22 2017 1:05am
liveforphysics wrote:So excited to fly in it!!!
Should be a good performer!
More pics to come.
Farfle   1 MW
Post by Farfle » Jun 22 2017 11:22am
Pics of the belt reduction:
mauimart   100 W
Post by mauimart » Jun 22 2017 2:10pm
Great project--can't wait to see it flying. What's the kV of that motor and what is the gear reduction? What size prop are you planning on spinning?
I am going to be embarking on a similar project with high school students. Starting in September we will be fabricating the EMG-6 (https://electricmotorglider.com/) with electric drive. Have not decided on the motor/prop as of yet but would like to do direct drive (no reduction). Here is another UL that used the Zero motor (https://www.youtube.com/watch?v=-eYIfGGk2yg&t=204s).
Best of luck to you.
Farfle   1 MW
Post by Farfle » Jun 22 2017 2:52pm
mauimart wrote:Great project--can't wait to see it flying. What's the kV of that motor and what is the gear reduction? What size prop are you planning on spinning?
I forget the motors Kv, But max speed is 6000 RPM and max power somewhere around 3300 RPM.
I plan on spinning a 62-66" two blade Powerfin "B" blade around 2850-3100 RPM. Current gear ratio is 30/65
fechter   100 GW
Post by fechter » Jun 22 2017 3:01pm
Do you need a FAA license to fly one of those?
Farfle   1 MW
Post by Farfle » Jun 22 2017 3:09pm
fechter wrote:Do you need a FAA license to fly one of those?
Nope! This is a FAA part 103 ultralight.
Post by liveforphysics » Jun 22 2017 3:52pm
A gen4. 5 will be a nice performance upgrade path for even shorter takeoffs assuming the airframe is up to it.
That bird with a couple linear actuators on the stick would make a fine 1:1 RC model.
SlowCo   100 kW
Post by SlowCo » Jun 22 2017 3:58pm
Wow, what an amazing project! I wish you well while building and a safe flight when it's done.
mauimart   100 W
Post by mauimart » Jun 22 2017 7:33pm
Can you clarify the battery pack? Is it 29Ah total or 4 x 29Ah? The latter would make a 12kWh pack. And what is the anticipated weight of battery?
Farfle   1 MW
Post by Farfle » Jun 22 2017 7:38pm
mauimart wrote:Can you clarify the battery pack? Is it 29Ah total or 4 x 29Ah? The latter would make a 12kWh pack. And what is the anticipated weight of battery?
The pack is 29Ah per cell with 4 in paralell for a roughly 12kwhr pack. Pack weight will be right at 67KGs
fechter   100 GW
Post by fechter » Jun 22 2017 9:12pm
liveforphysics wrote: That bird with a couple linear actuators on the stick would make a fine 1:1 RC model.
I was thinking the same thing. It could carry a nice payload.
marty   10 MW
Post by marty » Jun 22 2017 10:00pm
This reminds me of my radio controlled model airplanes. Was really into those before I was old enough to have a car, 12 to 15 years old? I am 56 now. Was better at building then flying. Crashed every plane. I still have the planes in my attic. Balsa wood, plastic covering that ya heat and shrink with a little iron, gas engines, servos, music wire. I liked flying the glider the best. Long rubber tubing to launch it.
Remember one plane. No throttle control? Had a experienced pilot fly it for me. Plane had a problem and kept flying higher and higher. Eventually the experienced pilot was able to get the plane to come down and land.
MARTY
Volt Electric Vehicles
http://www.voltev.com
litespeed   100 kW
Post by litespeed » Jun 23 2017 6:27am
That is really cool.
Tom
spinningmagnets   100 GW
Post by spinningmagnets » Jun 23 2017 7:06am
This is an awesome project, I look forward to the results.
I am reminded of the 1937 Fi-156 Fieseler Storch (Stork)
rojitor   100 kW
Post by rojitor » Jun 23 2017 12:49pm
Farfle   1 MW
Post by Farfle » Jun 24 2017 10:22am
spinningmagnets wrote:This is an awesome project, I look forward to the results.
[img]http://www.toni-clark.com/english/model ... M-PL_3.jpg
That Storch is a special kind of ugly, but a fairly good performer!
Matador   10 kW
Post by Matador » Jun 24 2017 10:35am
Wow ! OMG Wow ! I want one....
Brings back memories.... Me on coming back from my first solo :
And no more carb heat !
Hopefully it can take just enough G's for roman candles and lazy eights !
Matador
helno   1 W
Post by helno » Jun 24 2017 11:00am
How is your weight budget looking? Far 103 is pretty strict with that 254 lb limit.
Looks like it will have tons of power. Belite makes neat little planes.
neptronix   100 GW
Post by neptronix » Jun 24 2017 11:58am
Wow.. I've pimped this thread in the endless sphere facebook group because it is so damn rad.
Can't wait to see how it turns out; best wishes!
Efficiency is everything :bolt:
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
The monster scooter: ? on a Cannondale Semi Recumbent.
