Elephant in the room - Quadcopters...
Things that fly
LockH   100 GW
Re: Elephant in the room - Quadcopters...
Post by LockH » Jan 25 2019 4:54pm
^^ Hehe... "The problem with using electricity to create hydrogen from water is that it uses electricity. " Got plenty of water... plenty of cheap electricity via solar cells... and chemical cells as batterys never wear out... ermmm... ooops.
OTOH, hydrogen stored in tanks is cheap to make, renewable, and the tanks never wear out, etc etc etc... :wink:
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
amberwolf   100 GW
Post by amberwolf » Jan 25 2019 9:36pm
Tanks do wear out--every time they are pressurised, they are stressed. As pressure decreases, teh stresses change, reduce, etc. Then they are repressurized, etc. Cycling eventually causes stress fractures, which eventually can crack all the way thru.
Similarly, chemical generation units (fuel cells, etc) do wear out--sometimes it's from physical damage like the above, sometimes its' from impurities in either the original construction or in the materials passing thru it that then react with other things and cause increasing defects over time.
billvon   1 GW
1 GW
Post by billvon » Jan 26 2019 1:26pm
LockH wrote:
Jan 25 2019 4:54pm
As mentioned above, tanks do wear out - and hydrogen has an additional problem with being stored in them, because it causes hydrogen embrittlement of common tank materials (steel, aluminum etc.) You can coat them, of course, but that presents additional problems.
That's not to say it can't be done, of course. But the statement "hey, just put it in a tank; it's easy and cheap!" isn't even close to being true.
--bill von
LockH   100 GW
Post by LockH » Jan 27 2019 1:27am
Always look at the worst scenario... then imagine it ten times worse. :wink:
helno   1 W
Post by helno » Jan 29 2019 9:38pm
billvon wrote:
Jan 25 2019 4:43pm
But that's like saying I have an awesome method to create gold out of almost nothing! I'll be a millionaire, right? To create a gram of gold, I just start with three grams of diamonds and . . .
The plants I work at have neutron flux detectors that slowly turn to gold.
But they start out as Platinum....
billvon   1 GW
1 GW
Post by billvon » Jan 29 2019 9:46pm
helno wrote:
Jan 29 2019 9:38pm
It's always those details that get you . . .
--bill von
cricketo   10 kW
Post by cricketo » Jan 31 2019 1:33am
billvon wrote:
Jan 25 2019 4:43pm
Right. But that's like saying I have an awesome method to create gold out of almost nothing! I'll be a millionaire, right? To create a gram of gold, I just start with three grams of diamonds and . . .
The problem with using electricity to create hydrogen from water is that it uses electricity. And you'd be a lot better off using that electricity to just charge that EV in the first place. Converting it to hydrogen, storing it, transporting it, compressing it and then using it to power a fuel cell means you get about 1/3 of the energy you put in to making it.
Context is important. Battery-powered EVs are plenty useful given the weight / capacity / range. Same is not true when it comes to flying machines - they're constrained by weight, use more energy, so current battery tech isn't practical for their use. Electrical drivetrains have obvious benefits though, including in flying machines. So currently the only solution that comes to mind is chemical fuel consumed to generate electricity. What fuel, and how consumed is up to you. Hydrogen, methane, propane can be produced using electricity and be carbon neutral.
TheBeastie   1 MW
Post by TheBeastie » Feb 19 2019 2:37am
I assume everyone's seen this video of the 2-hour flying Hydrogen Fuel Cell drone, if not check it again here. There are bigger models out there that can fly for 4-hours straight on YouTube but these Intelligent Energy kits seem to be aimed the major more practical needs in the drone/quadcopter market, I think Intelligent Energy is aiming for what most people need more than ultra-extreme long distant flight applications.
Of course, none of this stuff is for kids as toys, this is expensive serious business stuff.
This video has a tiny amount of views for how cool it is, I think there are just too many arseholes out there that never click on the Like button on good videos.
https://youtu.be/AHlrLU7kTys
But now there is a NEW video just running through their Fuel-Cell/Hydrogen kit/power-pack on how straight forward it is to build your own quadcopter/drone from their kit (for those who are at least familiar with it all)
https://www.youtube.com/watch?v=xTVI_ISVWkY
Once 4th gen nuclear is up and running, using it to mass produce Hydrogen by splitting water will be a no-brainer formality IMO, officially most 4th gen nuclear is designed from the ground up to be able produce Hydrogen as well as electricity generation, unfortunately, explaining the technology and methods behind 4th gen nuclear is not easily absorbable or something that can effectively put placed in a single simple meme like RE does with a pictures of a wind-turbine saying "this can power the world" etc.
I go over that in some of my "pro-nuclear / hydrogen posts" links in my signature.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
Chalo   100 GW
Post by Chalo » Feb 19 2019 2:42am
TheBeastie wrote:
Feb 19 2019 2:37am
Or, like me, they have a look and think, "yeah, whatever".
I might change my mind about multirotors being fairly lame if we get some low budget, high value assassinations using them.
But I think they're fairly lame.
Grantmac   10 kW
Post by Grantmac » Feb 19 2019 12:27pm
Am I the only one thinking a 650w fuel cell would be a significant range extender on an ebike?
cricketo   10 kW
Post by cricketo » Feb 23 2019 12:11am
Grantmac wrote:
Feb 19 2019 12:27pm
It seems like 650W would have many practical applications. Any idea on the cost ? Also do they have a way to produce / store hydrogen, or the expectation is you'd take those cylinders elsewhere for filling ?
fechter   100 GW
Post by fechter » Feb 23 2019 2:30pm
They make a 800W version of the fuel cell, but their website does not show any pricing.
Maximum continuous power 800W
Maximum peak power 1400W
Output voltage 19.6V to 25.2V
Fuel Cell Power Module Dimensions 196 × 100 × 140mm
Mass 930g
Hydrogen Regulator Mass 250g
Maximum regulator (cylinder) pressure 300 Bar/4350 PSI
Output pressure 0.5 Bar ± 0.25 Bar/7 PSI ± 3 PSI
PRV set pressure 2 Bar/29 PSI
Burst disc set pressure 450 Bar/6500 PSI
Maximum cylinder mass 10kg
I would imagine you could refill the H2 tank where they refill fuel cell cars.
Grantmac   10 kW
Post by Grantmac » Feb 23 2019 2:41pm
If you have to ask, you probably can't afford it.
Commercial drones where time=money definitely make a several thousand dollar investment pay off quickly if they bid by the job rather than charge by the hour.
MitchJi   1 GW
1 GW
Post by MitchJi » Mar 30 2019 2:20pm
AmpEater wrote:
Oct 05 2010 7:48am
Edit - I assumed you were talking human-size quadcopters. RC scale has been done 1000 times by now, even open source projects with hardware available. That doesn't keep me from wanting one, of course. I have a thermal camera that would be awesome to get airborne, but is outside the payload of most smaller quads.
This is relevant
https://endless-sphere.com/forums/viewtopic.php?t=99409
Best Wishes!
Mitch
Buying a new Tesla? Please consider using our referral code https://ts.la/lynnem96959 to get one thousand miles of free Supercharging.
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Three examples are Chevy Volt and Nissan Leaf and Tesla Model 3 packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
TheBeastie   1 MW
Post by TheBeastie » Jul 25 2019 8:08am
Introducing the TF-19 Flamethrower Drone
Definitely looks like fun for the whole family :D
https://www.youtube.com/watch?v=07rtBip9ixk
TheBeastie   1 MW
Post by TheBeastie » Oct 16 2019 9:46am
I find the possibilities of fuel-cells fascinating since finding Hydrogen Fuel Cell quadcopters/drones claims that can fly for up to 4-hours straight in perfect ideal conditions with a large tank and nothing to carry like a camera/weight etc.
With the "fuel-cell flying electric car" also supposedly on the way https://interestingengineering.com/look ... es-is-here
Here is a large all in one FAQ Hydrogen Fuel Cell quadcopters/drone YouTube video to answer all the questions, the most obvious is that it's expensive gear, only for professional industrial use only, but who knows what 10 years can do.
This Drone Will Fly For One Hour Using A Hydrogen Fuel Cell: Here's How! 12 FAQ's
https://youtu.be/szTVfkVrLLI
TheBeastie   1 MW
Post by TheBeastie » Jan 08 2020 1:16am
Hyundai S-A1 Air Taxi.
Hyundai have a fair amount of fuel-cell EVs, so I wont be surprised that the finished product of their Air Taxi will be fuel-cell based as well.
If there was any group of people who should dubious of a miracle battery just around the corner its long-time ES forum dwellers viewtopic.php?f=14&t=57256
https://www.youtube.com/watch?v=L6K7GAG1Aas
goatman   10 kW
Post by goatman » Jan 13 2020 2:18am
TheBeastie wrote:
Jan 08 2020 1:16am
didn't that frenchman just fly across the English channel with a backpack battery?
Hillhater   100 GW
Post by Hillhater » Jan 13 2020 6:48am
goatman wrote:
Jan 13 2020 2:18am
No !
A French inventor has crossed the English Channel on a jet-powered hoverboard.
Franky Zapata's hoverboard is powered by kerosene which he carries in a backpack.
He took off from Sangatte near Calais and reached Dover in just over 20 minutes – but he had to stop for fuel.
goatman   10 kW
Post by goatman » Jan 13 2020 12:10pm
id like to see a vante black graphene solar hanglider with a little electric motor on it
TheBeastie   1 MW
Post by TheBeastie » Feb 05 2020 7:22am
Never seen these in before, now there are Drone and Plane ALL-IN-ONE.
Can do VTOL style flight because the motors can turn from vertical to a horizontal direction for more distance flights.
https://youtu.be/OOTacas2Iog
TheBeastie   1 MW
Post by TheBeastie » Mar 22 2020 11:47pm
In China, its routine to remove debris from powerlines using flamethrower quadcopters
https://www.youtube.com/watch?v=iOqWfLZT8OM
Hillhater   100 GW
Post by Hillhater » Mar 23 2020 8:54pm
TheBeastie wrote:
Mar 22 2020 11:47pm
:shock: why am i thinking ..”when riot control gets serious...”..??
